Wanted 3sp to 4sp swap parts
Looking for an sm420 4sp, floor hump, shifter, floor shift column, driveshaft. My truck is a 66 3/4 LWB. I'm in TN.
Got a parts truck? Can drive to pick-up in neighboring states if needed. Thanks for looking. Glen |
![]() Join Date: Aug 2008
Re: Wanted 3sp to 4sp swap parts
Parting out a '63 C30 with 4speed w/PTO in East TN if that will work for you.
#3 | |
I'd like to see what you have. Any chance you could snap a few shots inside the truck? Post here or my email is biggersboyz@rocketmail.com Thanks, Glen |
Let me see what I can do.
I was lucky to find a 3sp from a 65 pick-up local...same casting numbers for $100. Trans had been out in the garage for 20yrs, mint inside, dry outside.
I'll install a new clutch and keep going, then tear into the original over the winter to see what's up with it. Thanks to all for helping, guess keeping this truck original (3sp) was meant to be. Glen |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
You should be able to use your rear portion of your 2-piece driveshaft. I have the front portion.
I'll get you a measurement if you're interested. I also have the column.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Okay, I see now you have what you need.
