Old 11-06-2015, 05:38 PM   #1
magntik
Rear wheel well for a '72 Suburban
Can anybody tell me if someone is making/selling the outer rear wheel well for the suburbans?
Or at least give me some ideas on what was used to rebuild this area.
The lower panel where the 4th door would be is rusted and damaged, I got the repopped patch panel, but the inner structure pieces I can't locate. The lower front part of what I would call the wheel well needs replaced.
Any help is greatly appreciated.
Jeremy
magntik is offline   Reply With Quote
Old 11-06-2015, 08:12 PM   #2
casper71
Re: Rear wheel well for a '72 Suburban
They don't make this part. You can see if someone on the site is parting a suburban and get a piece cut out. Other option, which I did is to make new panels yourself. Take your time and check fit either way. Good luck.
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
