Old 11-08-2015, 12:46 AM   #1
teamadams
teamadams's Avatar
muncie 4 speed swap
I have a 64 short step with 3 on tree wanting to swap to Muncie 4 on floor is there a drive shaft available or do I have to have mine modified 5" shorter with a yolk to match the 4 speed output shaft ?
teamadams is offline   Reply With Quote
Old 11-08-2015, 02:04 AM   #2
64-454ss
64-454ss's Avatar
Re: muncie 4 speed swap
When I ran a Muncie in my 64, I found a driveshaft out of an S-10 that was perfect length for about $20. All I had to do was change the rear u-joint to match up to the 12 bolt rear. In fact, I believe the same driveshaft is still in there behind the automatic now. I think the slip yolk was the same fit between the Muncie and turbo 350.
64-454ss is offline   Reply With Quote
Old 11-08-2015, 02:29 PM   #3
frankslagoon
I also used a S10 shaft for a sag 4 sp.
frankslagoon is offline   Reply With Quote
Old 11-08-2015, 07:16 PM   #4
teamadams
teamadams's Avatar
OK thanks is the s10 a extended cab short box or reg cab long bed with manual trans any year ?
Old 11-09-2015, 02:49 PM   #5
teamadams
teamadams's Avatar
I found a reg cab short box s10 manual trans and drive shaft is 53" My drive shaft is 61" three speed is 16&1/2" Muncie m20 is 21&1/2" so I need a 56" drive shaft with 27 splines by my calculations . Is that what a s10 blazer has ? Any body know?
drive shaft, muncie m20, swap
