11-10-2015, 05:24 PM | #1 |
20" wheels on a ECE 4/6 kit ...??
Who's running a 4/6 drop kit on 20's? I'm about to pull the trigger on the ECE 4/6 kit. I currently have 17's all around with a 60 sidewall but thinking of going with a nice set of 20's.
11-10-2015, 05:47 PM | #2 |
67-72 parts collector,…
Re: 20" wheels on a ECE 4/6 kit ...??
It's all about wheel backspacing and overall tire diameter.
This is member 72BlkButys 69 on a 4.5/6 ECE drop. 20x8.5 and 20x10 with 255/40 and 295/40 tires.
11-10-2015, 05:57 PM | #3 |
That's pretty much the look I'm going for but I wondering if I do the 4/6 drop on my current set up it will be ok, then as funds permit I can get some nice 20's. Right now I have about 3 1/2 clearance in the front. Can anyone tell me if the 4/6 drop is a true 4" drop?
11-21-2015, 01:07 PM | #4 |
what backspacing do you need to run not to have any rubbing issues?
11-21-2015, 04:45 PM | #5 |
Every combo is different so there's not 1 correct (100% definite) answer.
11-21-2015, 08:10 PM | #6 |
11-21-2015, 08:37 PM | #7 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=674909
11-22-2015, 01:08 AM | #8 |
Always @ the top of your game brother!
