Old 11-10-2015, 08:03 PM   #1
1tuff71
1tuff71's Avatar
hooker exhaust
Has anyone used Hooker's custom exhaust system that bolts right up to the headers. This is a pre-bent kit they sell and wonder if it really is a simple bolt and go as they claim.
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 11-23-2015, 06:01 PM   #2
87Skier
87Skier's Avatar
Re: hooker exhaust
I believe we are talking about the same system here.
http://www.summitracing.com/parts/ho...t/model/blazer
Let me start by saying that I used a set of full length of Summit racing headers on my 72 Jimmy along with some cheap turbo mufflers. I ran into a few problems.
The instructions indicate that the exhaust should be installed under the frame rails just outside the transfer case. This didn't work at all for me because the pipes wouldn't clear the rear cross member and I didn't like the thought of it being that visible and open to getting crushed. I ended up running it above the transfer case and beside it above the cross member. This required cutting and welding to get the angles right. From there back it fit great. The tolerances were tight and it just cleared the axle, gas tank skid plate and everything else.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 11-23-2015, 06:35 PM   #3
1tuff71
1tuff71's Avatar
Re: hooker exhaust
thanks for the reply. I picked up that system and ran into the same problem. Sent it all back to Summit and decided to just go and see a guy in town that bends up a lot of hot rods. That was NOT a bolt on project.
