Old 11-23-2015, 01:00 AM   #1
RIDDLA
RIDDLA's Avatar
78 sm465 205 in a 71 Suburban
Well i was wondering if i could swap my 78 sm465 205 into my 71 auto suburban? Can i use the pedals and clutch linkage?
68 GMC-Stripshow
70 Chevy Monte Carlo
72 Chevy Monte Carlo LOLO
72 Chevy Suburban Blurban
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
03 Cadillac Escalade-Duecesix
84 Cadillac Coupe Deville DeElegance
B.O. A Lifestyle Money Cant Buy!
Win,Lose, or Tie
I'm a Raider till i die
RIDDLA is offline   Reply With Quote
Old 11-24-2015, 06:19 PM   #2
vectorit
What?
vectorit's Avatar
Re: 78 sm465 205 in a 71 Suburban
The trans/bell housing/tcase are fine, but you will most likely have to re position the cross member. Might even need to compare an AT cross member to the MT cross member?
Different drive shaft lengths.
The pedals, I would get out of a 67-72 MT truck.
Check for a Z bar bracket on the frame, and check for a provision in the engine block for a pivot ball stud just above the oil filter.
Finally, I have seen AT trucks that the engine crank did not have a hole for a pilot bearing. So beware.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-25-2015, 06:47 PM   #3
tedfrk
tedfrk's Avatar
my 71 suburban has an sm 465 and it is factory ,pretty sure the years dont differ.
tedfrk is offline   Reply With Quote
