Old 11-26-2015, 01:03 PM   #1
JAG123
89 Crew Body on a 76 Single Frame Help needed
Calling all gear heads, I need some help!
I'm putting a 89 Crew Cab body on a 76 single cab, long bed frame - which in essence is the same thing as a suburban frame I suppose.
I thought it would be as simple as bolting the body mounts to the factory location, and then cutting the rear floor out for the body to sit lower where the frame rises, but it's not.
I had to modify the middle mounts to line up with the cabs body mount location. I got them bolted up and here's how it looks.
middle mounts
inside cab
rear sitting off about 10 inches
How do I get the body to sit lower? Seems like something more is going to have to happen than "just lowering" the mounts. What am I missing here?
Thanks in advance
**UPDATE**
I moved the he "middle mounts" down, to bring the body down, and it looks a bit better now, however the front and rear are off about 3".
So the only real option I know, to fix the issue, is to drill new holes for the front mount, and move the cross member in the rear, to get them to line up.
I was hoping, someone else that has done this job, could shed some real details/light on the over all process, before I go crazy and mess something up!!
JAG123 is offline   Reply With Quote
Old 11-26-2015, 02:20 PM   #2
tinydb84
tinydb84's Avatar
Re: 89 Crew Body on a 76 Single Frame Help needed
This guy did it: http://67-72chevytrucks.com/vboard/s...=582618&page=2
its missing a lot of pics now but you can read and see some of the frame and cab pics on page two.
David
Instagram: myfabguy
Old 11-29-2015, 08:25 AM   #3
JAG123
Not quite the same, but an amazing build none the less!!
It seems it is going to need quite a lot of work to get it sitting right.. I don't think there is any way to use the factory locations for the cab mounts.
