Old 11-29-2015, 12:20 PM   #1
Reno
Reno's Avatar
1970 2WD Project
OK so I am gathering parts for my 1970 2WD restoration. It will be a full body off media blasted process….
My plans are to build with minor modifications, nothing that can't be reversed.
First off I need doors, mine are pretty rough - I have located a set of really clean 72 pickup / suburban doors that I was going to cut down. My question is it really a big deal that they will be 72 doors with the added screw below the wing window for support from GM or should I look for the correct style.
Looking for a 1972 single wall top as it has no top - again preference.
It has a 67 front clip on it now and I will be using this as I prefer the look...
I will be also adding disc brakes on all 4 wheels with 5 bolt lug pattern. Drop spindles on front and lowered in the rear….
I wouldn't think that any future Buyer would walk away due to these mods?
And finally it will be a LSx conversion - too much benefit not to go this route and again if someone had to they could reverse it to conventional V8
Thoughts?
Suggestions?
Reno is offline   Reply With Quote
Old 11-29-2015, 02:30 PM   #2
notsolo
notsolo's Avatar
Re: 1970 2WD Project
Sounds like a solid plan, more power with better brakes, if you build it right then you will enjoy driving it! then forget ever selling it in the future. Build what you want, I regret not going with a modern drive train. Only suggestion don't leave the seats till last and get 3 pt seat belts.....Is this an original 2wd, where were the shocks mounted in the rear? and Take plenty of photo's.
notsolo is offline   Reply With Quote
Old 11-29-2015, 05:08 PM   #3
hemi43
hemi43's Avatar
My truck is a 70 also, and has it's original doors. I have that added screw below the wing window.
hemi43 is offline   Reply With Quote
Old 11-29-2015, 08:03 PM   #4
Reno
Reno's Avatar
Yes its an original 2WD Blazer with CE vin matching numbers on frame rail. Not sure on other components being original, engine, trans, etc
