Old 12-03-2015, 09:52 PM   #1
mild68
mild68's Avatar
New here and introducing myself and truck
Hi guys, I just joined this board and look forward to learning what I can about these trucks and apply it to my build.
My name is Jerry. I live in Illinois and took a trip to Daytona Florida last week to go to the Turkey Run. Long story short I got a souvenir from Florida.
A 68 Chevy swb step side.
My plans for the truck are to tear it down, clean the paint the frame, under body and any and all components then reassemble. Doing a LS swap, Most likely 5 bolt wheels with front disc brakes, change out the cab fuel tank with a frame mount.
I have been reading posts and builds. If I can get some help and guidance as far as these changes I would appreciate saving me research time.
I need to find out what to use for front disc brakes. I think I can use 73 and up brakes as long as I use the control arms?
Not sure what to get for rear axles w 5 x5 pattern.
I was told I can use a 91ish Suburban gas tank in between the rear frame rails.
I'm almost done w a LS swap in a S 10, Any preference on LS motor mounts?
The truck does need patch panels that are with the truck. Rockers and cab corners. The wood in bed in nice.
mild68 is offline   Reply With Quote
Old 12-03-2015, 10:51 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: New here and introducing myself and truck
Looks like nice start. I'm in for the build.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 12-03-2015, 10:51 PM   #3
flashed
Nice truck you have there .
flashed is offline   Reply With Quote
Old 12-03-2015, 11:09 PM   #4
swamp rat
swamp rat's Avatar
Just pressed the 'like' button..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-03-2015, 11:15 PM   #5
dfwright
dfwright's Avatar
Congrats on the excellent souvenir! I'll be in for watching the build. I missed it, or you didn't mention anything about lowering? Will you be keeping it stock height?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-04-2015, 04:09 PM   #6
mild68
mild68's Avatar
thanks every one. I'm making a trip after Christmas to pick it up and bring it home.
I'm sure I'll lower it some what. Not sure how much yet. I've been looking thru builds and pictures and have seen some where I really like the stance. I also been thinking about going w a disc brake conversion and keeping the 6 lug and go with a late model 20" wheel. What I'm leaning towards is getting the body down to the tire.
Old 12-04-2015, 06:19 PM   #7
schmeed24
Sub'd.
schmeed24 is offline   Reply With Quote
Old 12-22-2015, 02:27 PM   #8
New_70'C10
New_70'C10's Avatar
I must say that's one of the best souvenirs I've ever seen. It must have been a great vacation. I've got a 70 I'm about to start on so I'm in to see what all ideas I can snag from your build. Good luck.
1970 SWB CST; 307ci, 200-4R, (Slow Motion)
New_70'C10 is offline   Reply With Quote
Old 12-22-2015, 05:06 PM   #9
CC69Rat
CC69Rat's Avatar
Congrats ! looks like a great start. I'm in for the build.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-22-2015, 10:10 PM   #10
boynton
boynton's Avatar
Awesome looking truck. Can't wait to see your progress. I did a 6.0 swap in a '70 last year (on a budgetish) you can use 71+ for disc brakes but you may be money ahead just ordering a 6 lug disc kit so you don't have to swap the rear axels. There are a few threads you can read thru for all the disc swap info you could ever need. In my build I listed parts as I used them but to directly answer your question, I used early classics sheet metal mounts in the stock v8 holes. I could have pushed the motor back about 3-4" and helped with weight distribution. You should also look at this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=358692
It helped me a bit. Some of the stuff was over my budget but it is fun to dream about.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 12-22-2015, 10:12 PM   #11
boynton
boynton's Avatar
Oh and you can pull 5 lug axels out of any 12 bolt that shares the same spline pattern
1970 SWB Step-Side
