Old 12-04-2015, 05:29 AM   #1
a1gatorz
a1gatorz's Avatar
Blazer back inside panels ?
Hi all , I own a 72 BLAZER & am wondering what would be the easiest way to fab up a pair of rear inside side panels ? Does any one hear have a templet available ? When I bought my truck they had no rear side panels , so I have nothing to go by . I have made a couple of attempts at making them , but I cant seem to get the inner fender shape correct . Also when I got it , it had truck doors on it with the window frame . I've been told its no problem to cut these off ? Any advise on best way to do this ? All help is welcomed ! THANK YOU !
a1gatorz is offline   Reply With Quote
Old 12-04-2015, 03:49 PM   #2
chad75
chad75's Avatar
Re: Blazer back inside panels ?
Would love a set too, Hard to believe no one makes them!
chad75 is offline   Reply With Quote
Old 12-04-2015, 05:53 PM   #3
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Here ya go.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-04-2015, 06:18 PM   #4
1rippen6
This guy should have them
http://67-72chevytrucks.com/vboard/s...d.php?t=689214
1rippen6 is offline   Reply With Quote
Old 12-04-2015, 06:20 PM   #5
1rippen6
Here's a better link
http://67-72chevytrucks.com/vboard/s...d.php?t=515957
Old 12-04-2015, 09:08 PM   #6
Walter White
Walter White's Avatar
I've been thinking I should trace one on cardboard from a classic truck parts store that I've been to. I would consider upholstering marine plywood and install speakers. I did that to my boat---its not complicated and quite inexpensive
Walter White is offline   Reply With Quote
Old 12-04-2015, 09:17 PM   #7
Walter White
Old 12-05-2015, 06:35 AM   #8
Walter White
Originally Posted by richard2717 View Post
Here ya go.
thats awesome-- i will use that diagram when i can get to it. thanks
Old 12-05-2015, 10:41 AM   #9
hemi43
hemi43's Avatar
You're having a problem making a template because you're trying to cut the complete shape all at once on one piece of card board. Make your template using 2-3" wide strips of stiff non-laminated cardboard like the stuff shoeboxes are made from. you can use short or long pieces along the perimeter of the box side, and glue or tape them together. Using this method you should be able to keep a tight tolerance to the actual shape of the truck.
hemi43 is offline   Reply With Quote
Old 12-09-2015, 07:41 AM   #10
a1gatorz
a1gatorz's Avatar
Big thanks to all ! The templet is just what I was hoping for . Any advice on helping me cut the window frames off my doors ?
Old 12-09-2015, 08:02 AM   #11
richard2717
This is the link i have saved for when I do mine. There may be others on the site as well. If you go to the top of the page here to the gray and white google box, you can find just about anything you need to do has already been done by someone on the site. Just type in truck door to blazer door (or whatever you may be looking for) make sure you change the search button from "web" to "67-72 trucks.com" to get more relevant results, and it will give you quite a few hits. Hope this helps
Richard
http://67-72chevytrucks.com/vboard/s...d.php?t=273729
Members I have met.
Old 12-09-2015, 02:50 PM   #12
cstanley
cstanley's Avatar
Here ya go.
Take a little caution with these. I'm the one who drew them, but I never verified for certain the radius at the top corners of the wheel wells. That's my disclaimer. Although I would love to hear from anyone who used these with success (or where changes could be made.). I was planning on throwing them on a cnc router eventually.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
