09-17-2003, 01:46 PM | #1 |
Designated A-hole!
Best headers
under $100? Need to fit with little or no mods.
Thanks, Krue
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
09-17-2003, 01:50 PM | #2 |
Formerly yellow72custom
Summit has headers on sale for $68 right now....i believe they are the same thing as Dynomax headers, which i have heard good things about on the board.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
09-17-2003, 01:58 PM | #3 |
After ordering some FlowTech headers and getting them from Summit I was NOT impressed when I pulled them out of the box. I sent them back, and I decided to save my $$$ and got some ceramic coated Hooker Competition headers instead. They look WAY better, and I believe will last a whole lot longer.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
09-17-2003, 02:05 PM | #4 |
Cobalt,
I bought some ceramic coated Hooker Competition headers for my 71 1/2 ton about 6 years ago from Summit. Looked good for about 2 years then the coating started flaking off and the header tube began rusting and pitting. In my opinion, they are not worth the $$. I will probably do what my brother did. He bought a pair of Hedman headers for his Chevelle and hot JET HOT coat them. His are now showing signs of age but still not as bad as mine and he's had his 2 years longer. I'll probably invest in cheaper headers and have them coated in the future. James |
09-17-2003, 02:06 PM | #5 |
you wouldn't happen to have the part number, do ya?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
09-17-2003, 05:06 PM | #6 |
Fabricate till you "puke"
Add about $40 to your 1st $100,& you can get painted Hooker comps through summit or Jegs......nice fit, heavvy tubes & flanges, &worth the bucks crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-17-2003, 05:14 PM | #7 |
I think I've heard negative things about every set of headers available on this board. I picked the Hookers because I heard the *least* amount of negative things.
I also thought about buying non-coated headers and then having them Jet Hot coated, but I heard it was more expensive than just buying them already coated. Was I wrong in that?
09-17-2003, 05:17 PM | #8 | |
09-17-2003, 05:19 PM | #9 |
HA! That's what I thought...but of course I guess it depends on how long you want them to last.
I don't think I have any worries. I'll be happy with mine.
09-17-2003, 05:20 PM | #10 |
Yep, more expensive if you have them coated. I bought the Hooker comps as well (after seeing a post from Cobalt). They look awsome and fit better than any header I've ever installed, and all 8 spark plugs are completely accessible. (note that I have angle-plug heads)
09-17-2003, 05:21 PM | #11 |
...oh good you ended up getting them. How did you seal them to the heads if you don't mind me asking? I haven't installed them yet. Do anything interesting with the collectors?
09-17-2003, 05:24 PM | #12 |
Designated A-hole!
OK does anyone have a pass. side ram horn to sell so I can run my truck and save another $40?
I hate not having my truck on the road!
09-17-2003, 05:26 PM | #13 | |
09-17-2003, 05:36 PM | #14 | |
09-17-2003, 05:43 PM | #15 |
Watch out for your cornhole !
These are the Summit brand coated which cost 189.00. They are actually Dynomax brand. These are on my neighbors truck, and as you can see, the collectors hang low as hell. My Hooker collectors were much higher than this. These are too low for a deeply lowered truck.
Kevin
09-17-2003, 06:02 PM | #16 |
There used to be a set of Chevelle shorty headers available through Summit. Does anyone have that part number?
1968 Chevy C10 Longbed Fleetside |
09-17-2003, 06:13 PM | #17 | |
09-17-2003, 09:37 PM | #18 |
krue, I have a driver's side one I think. Maybe you could cut a hole in the hood and put it on upside down? Redneck fix, I know.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
09-17-2003, 09:44 PM | #19 |
Designated A-hole!
Lordy I wish! I gotta find one or park the truck until I can put a new exhaust under it.
09-17-2003, 10:27 PM | #20 |
I have had real good luck with manifold gaskets. I do cut the flanges on each side of the center tubes. Neat thing about the manifold gaskets is you can start all the bolts then just drop the gaskets into place.
09-17-2003, 11:22 PM | #21 |
its all about the +6 inches
I do like mudder on my hooker super comps...except the cutting thing. Never done that, but I've never had a reason to either. They don't hang much at all, they are higher than the front cross member. They pretty much kick ass.
Krue, I think I may have the manifold you need. I'll have to check though. (Not sure which side I have...but i DO have one. |
09-17-2003, 11:48 PM | #22 |
Designated A-hole!
I really appeciate everybodies help!
09-17-2003, 11:54 PM | #23 |
Hey Krue,
Show me a pic of that stepside beauty!
Douglas King Independence, MO |
09-17-2003, 11:57 PM | #24 |
THE QUICKER FIXERUPER
I have read somewhere that dynomax headers are actually jet-hot coated I had a set on my truck for about 8 months with no problems. I now have Doug thorley headers they are great I bought the nickle chrome plated from summit because the ceramics were backorderd for a month They were $330.
09-18-2003, 12:22 AM | #25 |
Designated A-hole!
She's more like the Beast than the beauty...but since you asked.
Right now she's sporting rally's and 33's but I need more pics (I lost a lot when my computer died.)
