Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-11-2015, 06:32 PM   #1
sleepertruck72
sleepertruck72's Avatar
Question 89 s-10 2.5 distributor ?
I am trying to get a truck running for a friend of mine. 89 S-10 2.5. The distributor was removed. I stabbed it with #1 cyl at TDC, rotor pointing at #1 terminal. The injector will not spray fuel . If you wiggle the black/red wire into the distributor it will pulse the injector. I suspect its bad wiring/sensor inside the distributor...I will try another distributor. Also, compression is 145-150 on all cylinders... My question is : can the distributor can be installed using any terminal as #1 or is there a certain orientation of the distributor ? I really don't want to pull the timing cover to check for timing marks just yet
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 12-11-2015, 11:50 PM   #2
Zane M
Re: 89 s-10 2.5 distributor ?
As long as the #1 piston is at TDC on the compression stroke, you can make whatever terminal the rotor is pointing at when you drop it in number 1.
Zane M is offline   Reply With Quote
Old 12-12-2015, 02:51 AM   #3
sleepertruck72
Zane M,
I thought so.. I guess I need to do some more work
Thanks !
72 C20 Longbed
05 1500 Z71
Old 12-13-2015, 04:39 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
Pull the valve cover and set timing with both valves closed on #1. Super easy on this motor.
Old 12-15-2015, 12:03 AM   #5
sleepertruck72
Question Re: 89 s-10 2.5 distributor ?
Warrens69GMC,
I will as soon as I go back over there on Friday ...its a 45 minute drive
I do have another question.. I removed the distributor..It seems there is no slot for the distributor to line up and drive the oil pump ...Is this not like the old SBC ? Or is something broken ? Thanks
72 C20 Longbed
05 1500 Z71
Old 12-28-2015, 09:20 PM   #6
Myself
Yes, it should have a flat on the bottom to drive the oil pump.
Myself is offline   Reply With Quote
