12-15-2015, 09:17 PM | #1 |
Are the Door Panels the same??
...wondering if the 67-71 door panels will interchange..I have a 67 GMC and I really like the 69/70 pattern..plus I'm going to install power windows so I guess my concern is if the door handle hole matching up, right?
12-15-2015, 11:02 PM | #2 |
Re: Are the Door Panels the same??
you betcha
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
12-16-2015, 11:00 PM | #3 |
...Yo BowTie..does "you betcha" mean Yes the panels will fit? or "my concern is the door handle fitting"..either way..Thanks!
12-17-2015, 03:56 AM | #4 |
yes and yes. they will interchange between 67 and 71. they are all the same steel panel, just have different vinyl coverings. so the door handle locations should match up.
12-17-2015, 02:13 PM | #5 |
12-17-2015, 09:40 PM | #6 |
...what about 1972..wonder if they are the same size??
12-17-2015, 09:53 PM | #7 |
'72 door panels are the same size length and height but differ in depth. In '72 the General went to a plastic sculpted or contoured panel which necessitates use of a deeper or longer window crank mechanisim. Also uses a '72 only arm rest that will not inter-change with previous years.
Also there is a differance in '72 only doors. They will have a factory drilled or punched hole just below the vent window. Uses a screw to better support the vent window channel.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
12-18-2015, 03:32 PM | #8 | |
12-18-2015, 08:55 PM | #9 |
The window crank shaft actually projects out further from the face of the door because the '72 only door panel is contoured to fit the arm rest which projects away from the door. Not sure but think the differance is almost an 1'' in length. Search " 1972 door panel " and a pic will show better than I am explaining most likely. As they say, 1 pic is worth a 1,000 jumbled words,
