Old 12-22-2015, 04:20 AM   #1
Kevschevys
1966 P10 Step Van Restore Help Radiator Removal
I am Restoring this 1966 P-10 Step Van Bread Truck. I Can't get the radiator out to get at the water pump. I Need Help and suggestions please! I can't get it out the top because of the heater blower vent is in the way, and I can't get it out of the bottom because it's welded.. I have unbolted the six bolts that hold the radiator to the frame, so it moves around a bit. I started taking apart the frame bracket, but this is extremely difficult to get at the backing nuts. Has anyone ever pulled the Radiator out of a 1966 P10???
I have ordered the manuals, they won't get here until Saturday!
Kevschevys is offline   Reply With Quote
Old 03-18-2016, 11:17 AM   #2
graphix62
Re: 1966 P10 Step Van Restore Help Radiator Removal
was wondering how you got that radiator out. I have a 1967 P10 that i am working on.
graphix62 is offline   Reply With Quote
Old 03-20-2016, 01:25 AM   #3
swamp rat
swamp rat's Avatar
Not sure, but a thought occurred to me, can you jack the front end up and pull it out the bottom after removal of the belts, fan and pulley's? Or maybe the engine needs to come out thru the cab first, then the radiator the same way?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-24-2016, 05:50 PM   #4
Kevschevys
It was simple-take the metal brackets and sheet metal off the top-lots of sheet metal crews, and take the radiator out the top. Got mine running good, had to drop the tank again and fix the rear wiring harness run where the rat had chewed through. also, I have to yank the steering whell to fix the turn signal lever i busted off. so Fun to drive!!
Old 03-24-2016, 05:53 PM   #5
Kevschevys
Having Fun now!
Old 03-24-2016, 05:58 PM   #6
Kevschevys
Re: 1966 P10 Step Van Restore Help Radiator Removal PAINT?
Any thoughts on how/with what, to paint these things??? pretty ugly right now, and it ain't gonna go patina or shinola! I want to paint it solid and put my business advertising on it....
Old 03-24-2016, 06:15 PM   #7
Kevschevys
Take the whole sheet metal off where the hood latch is-all those brackets.
Old 02-24-2024, 01:05 PM   #8
preciador6
Painted yet?
preciador6 is offline   Reply With Quote
1966 p10, chevy, l6 230/250, radiator removal, step van
