12-25-2015, 03:48 PM | #1 |
Fleetside Tail Light Housing Question
I have media blasted and cleaned the tail light housings and back up light housings for a fleetside and have a dumb question. Do you paint the recessed area around the bulb sockets a reflective silver or white? I seem to remember seeing some step side (round) tail lights that were white over the entire face of the housing.
If they weren't painted with reflective paint originally, wouldn't it make sense to add a reflective paint to make them a little brighter? Thanks, POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
12-25-2015, 03:57 PM | #2 |
Re: Fleetside Tail Light Housing Question
Metallic silver I believe. In some cases I've used 3M mylar foil tape (like a mirror) to line the housings. I did that one the back of the speedo and fuel as well because the tach is so much brighter than the other gauges.
Since no one will ever see it, I'd use the most reflective coating you can. Here's what I did to mimic the originals; I then added the mylay foil tape to the deep recesses. No idea if it's fireproof though... it's just the expensive HVAC stuff.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 12-25-2015 at 04:03 PM. |
12-25-2015, 04:14 PM | #3 |
The Older Generation
I've used White paint, Silver paint, Chrome paint, and Cold Galvanizing Compound, and they all seem to work OK. The Cold Galvanizing Compound works the best for keeping any rust from starting inside the housings..... LockDoc
12-25-2015, 06:04 PM | #4 |
Old member
You can are you can use the LED's that cover it totally up! Like I did.
12-25-2015, 07:27 PM | #5 |
Thanks guys. I think Rustoleum has a new and improved "chrome" color that is pretty reflective, too. I'm going to experiment a little to see what I like best.
POP
12-25-2015, 11:39 PM | #6 |
I will look forward to your "after action" report, once you see what you like best
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
12-26-2015, 12:14 PM | #7 | |
Thanks for all the help. POP
12-26-2015, 12:47 PM | #8 |
They look really good! It should make a lot of difference in the brightness.... LockDoc
12-26-2015, 01:03 PM | #9 |
Old member
Looks good!The brighter you can make them stop lights the better I say!
12-26-2015, 05:30 PM | #10 |
They look great!
