Old 12-26-2015, 10:25 AM   #1
Ozzie
Dash light globes
Hi all, back on here after a long absence, I was wondering are all the twist in globes on the back of the instrument panel of a '69 c10 the same or are there different ones for indicators, high beam, gen light, etc. I notice some of the holders have numbers on them, does this mean anything?.
Thanks in advance and Merry Xmas to all
Ozzie
Ozzie is offline   Reply With Quote
Old 12-26-2015, 10:28 AM   #2
Re: Dash light globes
The mini bulbs are push-in, right? Are those what you are asking about? They are all the same for everything.
Old 12-26-2015, 10:34 AM   #3
Ozzie
Thanks Special-K, yes the push in ones that go in the black twist holder, I must have a couple of bung ones that need replacing.
Cheers for that.
Oz
Old 12-26-2015, 04:10 PM   #4
davepl
davepl's Avatar
Special K is usually right, but not today. I believe some are 194s and some are 168s.
Check your owner's manual to be sure, but I remember it as everything takes 194s except the turn signals, which are 168s.
1895s also interchange with 194s. The 194s are two candle power, the 168s are three, so I guess the turn signals are brighter.
I find the tach too bright relative to the other gauges so have experimented with 168s on the outboard edges, but never found a setup I liked.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-26-2015, 08:07 PM   #5
Ozzie
Thanks Dave
That sounds like the problem I'm having, I have moved the globes around and some work in places and not others, checked all contact points and earths on a new circuit board I installed. Thing is when I jump online to buy some new ones they don't specify the differences so its a bit of a hit and miss when I get them here in Australia, can get costly with the exchange rate the way it is and shipping.
Cheers, Oz
1969 C10 short fleetside A.C BB 402, 700R4, 9 inch with 3.7s Watts linkage
Rear 5" drop, Front 3 1/2" drop, Disc brakes
