Old 12-26-2015, 10:11 PM   #1
75Dually
75Dually's Avatar
1968 GMC Terra Firma
A new project came my way over the Christmas break. The below 1968 GMC. I have been looking through Craigslist for the past couple of years, and this truck showed up with an amazing price. I jumped on it right away and the previous owner even delivered it to the shop!
Right now it is a long bed 3/4 ton. The cab and front end are super straight. The bed on the passenger side is not in the best of shape, but can be fixed. The engine is a 305 V6, and I am going to rebuild the carb and get it to run on the original power plant for now. My plan is to put either: 1. 350 small block, 2. 454 big block, 3. (or my current preference) an LS motor. We will have to see what the budget is after I finish my Dually. This truck will get bagged and slammed to mother earth and lay frame. I will shorten the frame and do a short bed conversion. Not 100% sure on wheels just yet, still looking at some ideas. I want a Porterbuilt front suspension, and the rear I want an IRS either out of a Vette or maybe I will build something custom. Again the budget will have to be consulted.
BTW you can see my current project below. It is a 1975 Chevy dually. Some of you may have already seen it here on this forum. I am trying to get it complete enough to go to the 2016 Lone Star Throwdown at the end of February.
Stay tuned...
75Dually is offline   Reply With Quote
Old 12-27-2015, 01:44 PM   #2
75Dually
75Dually's Avatar
Re: 1968 GMC Terra Firma
So I have had these pictures for quite some time. If I go IRS this is what I will do. I'm a Corvette guy so this is right down my alley. Also I dig the cantilever airbag/shocks!
Old 12-31-2015, 02:08 AM   #3
75Dually
75Dually's Avatar
So I got the carb from the previous owner today. It was in a million pieces in a box! So when I got done with work today I watched a couple of YouTube videos on how to rebuild this particular model. This style of carb was used by GM in a ton of applications, and each one had there own special version. So I did the best I could to piece this thing back together, and actually it went back together better than I thought it would. I still need a new gasket set, but that will have to be ordered or see if I can pick up one locally.
If all goes well I want to see if I can get the truck to run by the end of the weekend.
Stay tuned
Old 12-31-2015, 07:21 PM   #4
75Dually
75Dually's Avatar
Well the discussion is now over concerning the V6 staying in this truck. I just sold it and the 4 speed transmission. I will take it out once the snow melts off.
Now the discussion turns to what will go back in place of the V6? I'm thinking 5.3 LS with a 4L60E would be the easiest and most affordable. Plus there is a ton of aftermarket parts to support it also. Hmmm... Maybe a 6.0 LS... Have to see what is out there!
Old 12-31-2015, 08:14 PM   #5
dragonball98312
dragonball98312's Avatar
Did you mean to post this in the 73-87 part of the board? Id love to get either a 67 or 68. Saw one of those 305s at my local wrecking yard, theyre beasts! Too bad there no aftermarket support for them, would be an interesting motor
dragonball98312 is offline   Reply With Quote
Old 12-31-2015, 10:45 PM   #6
75Dually
75Dually's Avatar
Thanks for catching that!
I have moved the thread to: http://67-72chevytrucks.com/vboard/s...=1#post7430138
1968, bagged, gmc, short bed, slammed
