01-01-2016, 01:27 PM | #1 |
Need input from sway bar guys please...
I posted this in my build http://www.67-72chevytrucks.com/vboa...16#post7430716 thread but since it doesn't get much attention I'm posting here as well...
Trying to get this big 1 1/4" sway bar fitted and ran into a little road block.. clearance between the cradle cross member and the bushing mounts only give me like 2 inches, and there is still no weight from motor and trans on it so that's going to get tighter.... Not sure what to do here. It doesn't leave much room for suspension travel... Any ideas? Anyone have pics or measurements on how much room you have with your dropped setup?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
01-01-2016, 02:02 PM | #2 |
Re: Need input from sway bar guys please...
Mine's about the same distance from the sway bar bushing to the tie rod adjuster as yours. I've never had a issue. I have 2.5" drop spindles and 2" drop springs.
1970 C10 Short Stepper with 71/72 front clip. |
01-01-2016, 02:08 PM | #3 |
The LCA bump stop will hit before the sway bar clamps. Also it would take 4" or 5" more drop at the wheel for that 2" to hit. How much drop spring do you have?
I checked mine with 1" drop coils, drop spindle (doesn't matter), full drivetrain and cab full of crap but no front clip. I get 2-3/4" there. Mine is the original smaller bar but that shouldn't be but 1/4" diff. You will also get a little room when you bolt it down and it will compress a little. Pic for comparison
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
01-01-2016, 02:16 PM | #4 |
I have actually read where guys with air ride using stock arms and sway bars cut a small amount off the sway bar where it sticks out the back of the bushing clamps and hits the engine cross member. You shouldn't be anywhere near that happening though.
01-01-2016, 05:55 PM | #5 |
01-01-2016, 05:58 PM | #6 |
Yours looks like the bigger sway bar.. how does it handle? I'm a bit worried it might be a bit TOO stiff with that 1 1/4" bar...
01-01-2016, 10:09 PM | #7 |
I don't have anything to add to the discussion, but.......
I had to read that title a second time a little slower. I was thinking, what in the........Lol!
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
01-01-2016, 10:24 PM | #8 | |
So in short the spacer is temporary because i didn't want to force fit the clamps since the weight of the truck was not there. Sorry for the long winded answer. Now my daughter wants to put funny faces:
01-01-2016, 10:41 PM | #9 |
so.. what you're tellin me is that THIS is gonna cause issues once I get more weight on it? My bushing brackets are directly on the frame with no spacers.... but after looking at your pic again... your bar doesnt seam to have the same bends mine does... this one is the 1/ 14" bar...
01-01-2016, 11:00 PM | #10 |
Your not going to have a issue. I've installed a sway bar the exact same way before. I had a 4 1/2 drop on the front. On my current truck I could have done it the same way, but I bought the lowered style brackets which bring the bar up further than the stock style sway bar brackets on the frame.
Scott |
01-01-2016, 11:13 PM | #11 | |
01-01-2016, 11:26 PM | #12 |
Wasnt much of a fight at all... the holes in the Lower A-arm lined right up so I bolted it up to them and then marked and drilled holes in the frame for the frame mounts... and Thank you for the help. Much appreciated.
01-01-2016, 11:32 PM | #13 | |
01-02-2016, 12:32 AM | #14 | |
1. Lowered vehicle style
Scott Last edited by sduckworth13; 01-02-2016 at 09:40 AM. Reason: Spell check |
01-02-2016, 12:36 AM | #15 |
Here is the standard style sway bar bracket.
Scott |
01-02-2016, 12:51 AM | #16 |
Thanks for that.. I guess its better that I didn't use any of those then since I'm 5.5" drop...
01-02-2016, 01:05 AM | #17 |
Thanks Scott, I should have shown an original bracket pic. Here is an installed original bar and bracket pic and the sway bar faq thread with lots of tech, pics, and ways to mount the sway bar.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
01-02-2016, 08:39 AM | #18 |
It's 1-1/4" bar....handles great. I don't think it's stiff. As the description notes, it keeps the truck from swaying in turns or around corners. Truck still leans a little, but not flat in the turns like a corvette. I believe that is the size most are putting on the front of their trucks. I also have the S/B lowering brackets....
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 01-02-2016 at 10:52 AM. |
01-02-2016, 09:17 AM | #19 |
I pulled my 1 1/4" bar and brackets from a p body van.
And the frame brackets look almost exactly like the lowerd ones the vendors sell. They are certainly alot lower the the kids oe brackets. I had to check mine again after seeing yours and I have rite about 2 7/8" clearance but I only have 2" springs. But it really doesn't look like it could hit the clamps/bushing. I layed a rule in there and mine would only hit the small part of the bar that sticks out the back of the bushing. It would really need to travel to do that. Kids truck has the smaller bar and I could note a definite differance in the body roll between the two of them. Sorry for the crappy pic
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
