01-01-2016, 03:04 PM | #1 |
17" 6x5.5" rims with 4.25" center bore
My son has a 1970 C10 pickup that we want to upgrade the wheels and tires to 17". Does anyone know manufacturers and/or line names for 17" 6x5.5" wheels with 4.25" center bore?
Thanks, Bow Tie Bros |
01-01-2016, 04:10 PM | #2 |
Re: 17" 6x5.5" rims with 4.25" center bore
I think those are the Toyota FJ steel rims, not an aftermarket solution.
If you haven't done a disc upgrade yet, I would seriously consider doing so and switching to 5 lug at the same time. This opens up an infinite number of wheel options then. I did ECE conversion on my front with a '72 5 lug leaf rear. On your 70, drums and axles will get you 5 lug in the rear. I think the ECE way is to go on the front and keep drum size ball joints and tie rod ends. Welcome to the board.
