Old 01-01-2016, 03:17 PM   #1
99yukon
99 yukon drivers window
on the window harness plug that goes to the window switch block......which wires will make the window go up?...I have no meter or test light.......the window went down n will not go up.....NOTE....this happened a few months ago...same prob...but it went back up
thnks mike
99yukon is offline   Reply With Quote
Old 01-01-2016, 03:49 PM   #2
grumpyolddog
Re: 99 yukon drivers window
Sounds like the switch is the problem, use a battery from a drill to power it to the widow motor. Jump+ to one wire and - to the other, if it does not work reverse the wires. One way powers the motor up and the other the motor down.
grumpyolddog is offline   Reply With Quote
Old 01-01-2016, 03:56 PM   #3
99yukon
thanks for the reply....I was hoping I didn't have to take the door panel off....never had much luck getting it back on ...any way I can jump it on the window harness?...plug?..if so....what wires do I need to jump?........thanks!
Old 01-02-2016, 12:34 AM   #4
grumpyolddog
Try a different switch
