01-01-2016, 08:07 PM | #1 |
Bed Installation
I'm having some trouble mounting my bed. I had bought the 69 c10 longbed off of a guy on Craigslist the truck had no bed. I searched for about two months and finally found the be I have always wanted a fleetside. The problem that I'm having is that the bed sets above the body line. I have seen many people on the Forum say that the beds are interchangeable but I'm not too sure.
Bottom Line do i evidently have the wrong bed for the frame? I have pictures but i wasn't allowed to upload them or something. |
01-01-2016, 08:23 PM | #2 |
Re: Bed Installation
Pictures? Did you use new bushings for mounting the bed? There will be a major difference between using new bushings for mounting the bed and keeping the old under the cab.
01-01-2016, 08:25 PM | #3 |
could be the cab bushings are shot and letting the cab sit too low and make you think its the bed pics might help
01-01-2016, 08:32 PM | #4 |
01-01-2016, 08:44 PM | #5 |
looking at that picture your cab mounts are shot .lots of work ahead ...
01-01-2016, 08:49 PM | #6 |
ya the second pic makes it look like cab mounts are gone
01-01-2016, 08:49 PM | #7 |
01-01-2016, 08:53 PM | #8 |
GT you and Firedemon talked about the bushings do you know where i could find some i have looked on LMC but was unable to find some.
01-01-2016, 08:53 PM | #9 |
These trucks don't have to be a "money hole " barter trade and search for the deals . Do you have all the equipment / space time and money to rebuild it ?
01-01-2016, 08:54 PM | #10 |
There shouldn't be bushings under the bed. Are your cross sills that the bed bolts go through sitting down on the frame? It should sit down right on them. Looks like they are up off the frame a little. Are you parked on a level pad?
-Cody |
01-01-2016, 09:00 PM | #11 |
I would bolt the bed down tight and even side to side and square and go from there. You will be able to see how far the back of the cab is down if you stand back and look at the angles of the body lines
I keep the cost down on my projects by doing things myself and having a huge reserve in parts stashed. If I need something specific or looking for another project, I will wait to come across it than look for it and try to buy. I learned a long time ago to save stuff and that you will usually find a good deal shortly after paying high for something
-Cody Last edited by Gmc.guy; 01-01-2016 at 09:05 PM. Reason: Added paragraph, to save a third post in a row |
01-01-2016, 09:04 PM | #12 |
I get all of my parts from here. You will find everything that you can possibly need.
http://www.classicparts.com Gmc guy is right though. There aren't any bushings for the bed. It seems like the mounting brackets for the bed need to be pushed back a little so the bed can set down on the frame right. |
01-01-2016, 09:21 PM | #13 |
no theres not bushings for the bed but look at the pics the rear cab mount looks like its right through the floor or totally missing the rubber .jmedwards lmc does sell them page 17in the summer 2015 catalog along with most of the vendors on here classic industries gmc pauls brothers
01-01-2016, 09:31 PM | #14 |
Are there any bushings under the cab? I don't see any...
01-01-2016, 09:35 PM | #15 |
The cab mounts are shot ,for get the bed you need to get that cab back in solid shape before anything else , The cab corners are folded under and laying on the frame = Wacked !
01-01-2016, 09:43 PM | #16 |
Yeah but what is also going on with the frame; I see something has been welded to it in the one picture...
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
01-01-2016, 09:46 PM | #17 |
01-01-2016, 09:54 PM | #18 |
This is a cut frame ? that's coming apart ? Stop right there it needs to come apart stop trying to put together your wasting your time , Post pictures of the rest of the truck before going any farther you may just need to STOP and reconsider your plans !!!
Everything I see in the pictures makes this truck a parts donor not a builder . |
01-01-2016, 10:00 PM | #19 |
It has never been cut to my knowledge, I asked the PO he had said it was put on due to the fact that it has a quarter size hole at the top. I asked why it had a hole and he replied with it previously had rust.
01-01-2016, 10:04 PM | #20 |
Stop what your doing and remove the bed and get some good pictures of that frame and let some of us who play with these things daily give you some friendly advice before you waste a lot of time and effort . pictures .pictures .pictures !
01-01-2016, 10:05 PM | #21 | ||
"I ain't nobody, dork."
Might be time to look for a different cab... or different truck altogether.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-01-2016, 10:07 PM | #22 |
Due to the fact that i have already registered it and that not many c10s are on Craigslist that is can afford.
01-01-2016, 10:16 PM | #23 |
None of that will matter if it self destructs when your driving down the road ,With the cab mounts that bad I wouldn't consider driving it anywhere .
01-01-2016, 10:18 PM | #24 |
01-01-2016, 10:23 PM | #25 |
a low price doesn't always mean a good deal , post a lot of pictures so we can help you out with whats important first .
