Old 01-08-2016, 07:32 PM   #1
IndyBowtie
IndyBowtie's Avatar
'48 Chevy Restomod pick up
Have decided that after driving my restomod '48 for 5 years that it was time to scrap the stock rear leaf springs in favor of air ride. I don't think I ever started a build thread on it though. Started with a complete stock field find '48, ran the 216 for a year with a T 5 behind it, switched to a 283, same T 5, for another 4 years, now 700R4, 69 Nova rear, 3:08 gears, Fatman Fab MII up front, Easy wire harness , 89 Chevy 60/40 bench,stock column, added an Old Air Prod a/c and heat, steelies and moons, Diamondback whitewalls of course, last winter changed stock radiator to a 3 row aluminum with electric fans, 39 Chevy sedan LED taillights, and air ride and TCI 4 link.
Have 4 link in and gas tank repositioned, air tank and valves in and wired, mocking up 1x1 frame for new bed floor height. Tank and compressors will be under floor of bed, rear connected and working, have Fatman conversion for front end to air bags
A few pics...
IndyBowtie is offline   Reply With Quote
Old 01-08-2016, 07:36 PM   #2
IndyBowtie
IndyBowtie's Avatar
Re: '48 Chevy Restomod pick up
I tow vintage campers with it and for several years restored campers so quite a few pics of it hooked to campers...latest is very complete copy of a 1959 Scotty rear door camper
Old 01-08-2016, 07:37 PM   #3
IndyBowtie
IndyBowtie's Avatar
Tank repositioned behind axle, fill behind fender
Old 01-08-2016, 07:39 PM   #4
IndyBowtie
IndyBowtie's Avatar
Tank and valves installed
Old 01-08-2016, 07:42 PM   #5
IndyBowtie
IndyBowtie's Avatar
Fairly stock 283
Old 01-08-2016, 07:45 PM   #6
IndyBowtie
IndyBowtie's Avatar
TCI 4 link, this will not be a lay it on the ground set up, aired out the boards will be 4" off the ground
Old 01-08-2016, 08:00 PM   #7
Chance48
Nice looking truck! You should lay frame....would blow the old fellas mind when they saw that classy beaut hit the floor.
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
