01-08-2016, 10:06 PM | #1 |
12 bolt ring gear contact pattern help
Hey everyone looking for a little help setting up my ring and pinion.
65 c10 12 bolt Richmond 3.42 All new timken bearings Pics are of my starting point. I started with .030 under the pinion and .008 backlash. Need to know where to go from here to get a good contact pattern. Thank you for any and all help. I can only load one pic at a time for some reason I'll follow with the other side in just a moment |
01-08-2016, 10:09 PM | #2 |
Re: 12 bolt right gear contact pattern help
Here is the other side
01-08-2016, 11:06 PM | #3 |
Re: 12 bolt ring gear contact pattern help
That looks really good to me. I would sew it up.
01-08-2016, 11:24 PM | #4 |
Looks pretty good to me also
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-09-2016, 01:09 AM | #5 |
60-66 Nut
I agree, that looks pretty good to me. However someone with more setup experience may have different input.
01-09-2016, 03:58 AM | #6 |
I thought I'd looked good but I wasn't sure. This was the first setup to get a starting point. I guess I got lucky first try. Thank you guys!
01-09-2016, 09:49 AM | #7 |
That does look pretty good . I would remove .002 from the shim and see what you get . I see a hard straight line at the bottom of the pattern on both sides which may mean it may be a little to deep . And then play with the B/L .007 to .009 and see what it looks like . I would try this before I buttoned it up to see if it improves some .
Also you have a slight round moon shape at the top of the pattern . This also suggest its a little deep . It would run like you have it ok . But I like to get the best I can . Last edited by homemade87; 01-09-2016 at 09:56 AM. |
01-09-2016, 02:03 PM | #8 | |
Thank you for your input! |
01-09-2016, 02:23 PM | #9 | ||
"I ain't nobody, dork."
Loos decent to me.
You can load more than one pic in a single post. Just load them one at a time in the same post. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-09-2016, 04:09 PM | #10 |
Still only letting me upload one pic at a time not sure why...
I pulled .002 from the pinion and backlash is not at .007. I liked the first pattern better but I'm still learning the contact patterns. |
01-09-2016, 04:10 PM | #11 |
Here's the other side
01-09-2016, 05:02 PM | #12 |
Looks as if the drive side is better . You lost that hard line at the bottom . It also looks like it has centered the pattern from heal to toe and top to root on the drive side . Has that soft pattern all around with out hard lines . The coast side looks pretty good as well . Your roll pattern is a little soft . Re roll and get some pressure on the ring gear so the pattern would be more pronounced and re post .
01-09-2016, 07:13 PM | #13 |
Here are the pics you requested...
01-09-2016, 07:14 PM | #14 |
And the other side...
01-09-2016, 07:34 PM | #15 |
In my opinion , that looks really good . I would run that . Good even pattern top to bottom , smooth lines , pattern center coast and drive side . I would run it .
Check your back lash 3 places . If you average .007 to .008 you should be good . Some aftermarket gears can be a bear to set up . Unfortunately there are no oem gears out there for the 12 bolt . Gm quit making them years ago . AAM makes gm oem gears now and do not have 12 bolt gears . The Richmond orange box gears are not known for being quiet . It is a hit and miss . 3.42 gears are not as bad as the 4.11 and up . Last edited by homemade87; 01-09-2016 at 07:51 PM. |
01-09-2016, 07:44 PM | #16 |
Thank you very much for your help! It's greatly appreciated!
01-14-2020, 06:15 PM | #17 |
What do you guys think about this pattern? More pinion shim?
01-14-2020, 10:07 PM | #18 |
Still on setup bearings. Backlash at .008. I think I’m going with a pinion spacer instead of crush sleeve.
01-14-2020, 10:13 PM | #19 |
Post Whore
I was editing my post to show pics and somehow deleted it... the pattern looks good...id try it...but keep in mind things change when you swap out the setup bearings...crush sleeve eliminator is a good choice but will require more setup
01-14-2020, 10:19 PM | #20 |
Thanks Mongo. Looked pretty close to me but this is my first attempt at a diff setup. Based on the pics above, a little adjustment makes a big difference.
01-14-2020, 10:52 PM | #21 |
Post Whore
yep...just swapping out the bearing can change it all..it did on mine
01-15-2020, 12:15 PM | #22 |
Hopefully it won't change too much. I bought a new pinion bearing for setup. I bent the cage on the old one getting it pressed off.
I don't think anyone has been in this diff before. Looks pretty dang good for 50 years old. The backlash was loose and it wasn't posi so I decided to tear into it. |
