5.3 Power Steering pulley
I need a smaller diameter pulley for my truck power steering pump
Must be one inch smaller in diameter, is there something I can replace this press on ribbed pulley with???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Re: 5.3 Power Steering pulley
88ish Ford van with the 300 I6 is the common replacement.http://ls1tech.com/forums/conversion...swap-pics.html
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Buick 3800 v6 pulley is another option.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
meowMEOWmeowMEOW
Are you running into clearance issues w/ the frame?
Just keep in mind that a smaller pulley will change the pump speed and alter the boost pressure. Thats fine as long as it all feels ok, just keep an eye out for foaming and run a PS cooler if you notice any discoloration in the fluid or hot ps lines.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
O K, I suspected the pressure would increase, because it will be running faster right, will this change the steering feel or the Hydro boost pressure (braking) at high speeds, high RPM's
!0 -4 on the in line cooler
This looks like the right one
Thanks AGAIN !!! Color/Finish Black Groove Quantity 6 Installation Hardware Included No Installation Instructions Included No Item Grade Standard Replacement Material Steel Outside Diameter (in) 5.8125 Package Contents Pulley Pulley Bore 0.7472 Pulley Type Serpentine
Another option would be a pulley from Howe. I have a Saginaw T/C pump on an LS1 (not a truck) I went with a smaller Howe pulley to pull more flow out of the pump for the hydraulic rack I was using, but you could do as Brew City suggests and run a cooler to cut down on foaming/heating on yours
Here's a link- http://www.howeperformance.com/parts/tc-pump-pulleys/ |
I ordered a Doorman 300-132 be here in a hour !!!
Well it looks nice !
Still need more room, it will not clear the pressure portion of the Rack 5 13/16 still to large Howe only makes V belt pulley, & CFS racing. March has a 5 1/2"
Hey Solid. Was up early this morning and read your dilemma. So with nothing better to do, I checked out the Dorman catalog. here's some more pulleys you could check. They all are 6 rib with a center bore of .7472"
p/n 300-117 5.3" p/n 300-131 5.5" p/n 300-132 5.8" p/n 300-123 5.18" |
GREAT Lee!!
Thanks I am going to order the 300-123 I will tell the counter man he ordered the wrong one it is 123, not 132!! Thanks again for the help
#12 | |
#13 |
Well as long as there is not much left hand torque there is enough clearance between the high pressure port/hose this one is going to work (Dorman300-123)
Thanks Folks!
