Torque Converter switch stuck???
Just saw a code that said the torque switch was stuck on!
Isn't that controlled by the ECM? I cleared the faults so I guess I will see if it comes back on!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
meowMEOWmeowMEOW
Re: Torque Converter switch stuck???
How bout posting the code #
It uses input from the brake switch, so I'd check your wiring and adjustment on that before things get panicky.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Thanks Br3w
I erased it too quickly! I will start with the stop/cruise T/C wiring, may have pinched a wire.
