Old 01-14-2016, 12:01 PM   #1
tabs2471
Cool 1972 Blazer rear end yoke grease cover
Hi everyone.....I have a question about the rear pinion yoke on my 72 Blazer......the dust cover on the yoke separated from the yoke....making a terrible rattling sound because it moves and spins freely....I think I know the answer but I want to be sure....do I have to replace the whole yoke with new cover since they are supposed to be attached? Also, if I do replace it, how much do I torque the bolt back down once removed? I tried looking up that info and seems that I cannot find a direct answer. Thanks!
tabs2471 is offline   Reply With Quote
Old 01-15-2016, 06:56 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: 1972 Blazer rear end yoke grease cover
bump
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 01-18-2016, 01:38 PM   #3
cleszkie
cleszkie's Avatar
If your pinion seal is not leaking, I would remove the yoke nut with an impact wrench, pull the yoke off with a puller tool, and remove the offending dust cover. From here, you could either reassemble the yoke without the dust cover, or source out a new dust cover and press it onto the yoke before you reassemble it. If you like to do things by brute force, you could just cut off the offending dust cover with and angle grinder without removing the yoke.
cleszkie is offline   Reply With Quote
Old 01-18-2016, 07:33 PM   #4
tjsblazer
tjsblazer's Avatar
I agree. Unless you have a leak. I wouldn't pull stuff apart until I had to. Cut it off or could you put two small tack welds on it. 180* from one another.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-21-2016, 06:52 PM   #5
tabs2471
I appreciate the responses. The seal isn't leaking so I went ahead and cut it off! Thanks!
