01-18-2016, 09:49 PM | #1 |
Is this the right heater core
So today upon changing some hoses I got really luck and tore off a nipple from the old heater core, I've done a little research on people getting aluminum cores and others saying to go brass.
Has anyone got this brass one from autozone and it be a better fit than the aluminum ones http://m.autozone.com/cooling-heating-and-climate-control/heater-core/pro-source-heater-core/chevrolet/blazer-4wd/1972/8-cylinders-5-7l-4bl-ohv/470359_0_0/?location= Posted via Mobile Device |
01-19-2016, 12:23 AM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Is this the right heater core
I used this one. Been in the Blazer for more than 10 years.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
01-19-2016, 09:09 AM | #3 |
01-19-2016, 11:57 AM | #4 |
I either got it from Pep Boys or Napa, can't remember.
It fit right in. No modification to the stock brackets. This is an A/C core. The tubes are routed different on a non A/C heater core.
01-19-2016, 12:35 PM | #5 | |
01-19-2016, 08:07 PM | #6 |
can anyone give me some advice on how to disconnect the. Temperature cable so I can get the heater box off?
01-19-2016, 08:51 PM | #7 |
Those pal nuts can be a son of a gun, I usually just grab them with channel locks and rip them off, make sure you have a source for a new one, haven't ever been able to save them
Once you get them off, you'll see 2 or 3 paws that grip the rod. that's the problem, haven't been able to release and reuse them
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
