Before we try to start the 1966 Viking diesel....
My friend inherited a 66 Viking with a Detroit Diesel engine. We would like to fire it up and see if it runs although we are not sure when it was last running.
The engine does rotate so it is not seized but what can we do to get some oil circulating in the engine? Spray a bit of wd 40 into the cylinders, take off the valve cover and pour some oil on the moving parts? Thanks for any suggestions I may be unaware of. |
Re: Before we try to start the 1966 Viking diesel....
Disconnect the fuel relay and crank it to build oil pressure.
![]() Join Date: Jun 2014
if it is a detroit need to take off the valve cover and make sure the rack is loose. should clamp a pair of vise grip on the rack so you can shut it down if it starts to run away.
short bed are just cars without trunk lids trucks have long beds real trucks are longhorn ![]() 72 gmc 2500 longhorn 68 chevy c-30 50th anniv. 9ft step side 68 gmc crackerbox 8v71 detroit 72 gmc astro95 8v71 detroit |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Did you get it running?
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
