Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-20-2016, 11:05 AM   #1
NCD1966
NCD1966's Avatar
5 on 5 or 5 on 4.75 lugs
I have a 66 short stepper with 350 sbc with 3 speed OD. my little motor makes about 400 hp.
I owned a 98 trans am LS1 and it was my daily driver and bracket raced it about twice a month. So I grew into modding LS stuff and there is so much more hp to get out of them.
my truck will be turning into a bracket/ street cruiser. I will be selling my 350 engine and going with a 6.0 with ls3 heads and doing a carb setup with Th400 and possibly a gear vendors OD later on.
I looking at 5 lug disk brake conversion. I know 5 on 5 is common. What do most of you guys run? I asking this because of wheel options.
Seems like there are more options for the 5 on 4.75
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 01-20-2016, 12:54 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: 5 on 5 or 5 on 4.75 lugs
I switched mine to 4.75, way more wheel options in variety and size available, plus when you want to change it up way easier to sell your old set, I have a set of 5x5 Draglites I've been trying to sell but no truck guys in search, if they were 4.75 they would have sold by now.
Also my front Wilwood hubs didn't come in 5x5 so that's another option that was limited with the larger pattern.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 01-20-2016, 01:04 PM   #3
Project86
Switch your front hubs for 91 camaro 1le disc brakes. Share same inner and outer bearings. There are threads on here about that. As for the rear end I would get rid of the drums. Get some aftermarket axles. And put on a wilwood rear dynalite kit.
Project86 is offline   Reply With Quote
Old 01-20-2016, 01:29 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
The more torque you make the larger bolt patern is more desired. Top fuel still uses 5 on 5 and is pretty much a standard in the upper end racing (1000HP and above) But then too ONE SFI wheel for those guys is $1200+ and selection is VERY limited like 71 says.
Mark Williams 11" ProMod rear end is only offered in 5/8" studs and 5 or 5-1/2" bolt circle just as an example. Sooo like everything,, it's all just a matter of money.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-20-2016, 03:18 PM   #5
ptc
ptc's Avatar
Most of your Wilwood kits all come with multi-pattern bolt circles for the rotors and hats on both front and rear. They are typically 5 on 4.5" and 5 on 4.75" for Ford or Chevy.
Since many people use a Ford 9" rear end the pattern is typically 5 on 4.5" if the standard axles are retained. Strange and Auburn also make their axles in 5 on 4.5" pattern to meet the existing or have them custom built. Mine are Strange 4.5"
Weld Race wheels also come in the multi pattern bolt circle. 5 on 4.5" and 5 on 4.75"
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 01-20-2016, 03:55 PM   #6
ChrisDollins
ChrisDollins's Avatar
I'm with you. Always played with 4th gen fbodies and got use to easy wheel selection. My truck is 5x5 on the front and still 6 lug on the back until I decide what to do. It's hard to find what you want in 5x5 pattern without going custom. Although a set of old school cragar s/s 15x4.5 and 15x10's would look cool with some bias plys.
Chris
ChrisDollins is offline   Reply With Quote
Old 01-20-2016, 04:12 PM   #7
NCD1966
NCD1966's Avatar
Thanks guys for the response. That answered my question, looks like 4.75 it is.
I always run 2 sets of rims and tires for my street strip cars. My Trans am had 17x9 and 17x10.5 for the street and 15" drag lites for the track.
I like black steelies and wide whites look on my 66 for the street but I want to have a set of 15x10s and 15x4.5s for the track. I will probably run some M/T drag radials 325/50/15s out back.
not really sure what rim i will go with for the drag setup. It can wait for a while anyways.
I thought about cragar s/s for the track but might go to a modern/light type of drag rim
