Old 01-21-2016, 09:47 PM   #1
bmph8er
question about a mud only truck
I am building a mud only truck and looking for 1.5-2 inchs more lift. it has brand new 8 inch springs and I'm in the middle of a 4.5 inch drop perch build. now besides axle wrap and generally being unsafe on the road would it be that bad of a idea to build my own zero rate addaleafs? just make them a bit thicker? ill still be bolting to the spring. I have 3 inchs extra on the ubolts I haven't cut off yet so I think I can do a 1.5 inch safely. what do you guys think?
these are the 1 inch zero rates http://www.offroaddesign.com/catalog/Zero%20Rates.htm
bmph8er is offline   Reply With Quote
Old 01-30-2016, 04:13 PM   #2
74CustomK20
74CustomK20's Avatar
Re: question about a mud only truck
I had a set, with no real problems, on the road now as I needed to relocate the front axle because of my 52" spring swap. I had a 8" lift (spring front block n add a leaf rear) for a while n it was fun. Then I swapped 12" Springs front I got for cheap and added a diy4x rear shackle flip. Add all that with a 3" BL and I had 15 inches of lift.
Sorry for the ramble. I don't see a problem lol.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
