rhino lining
Have any of u guys rhino lined the inside of ur ride? I'm kinda thinking of doing a nice even layer of rhino line and install my carpet over it. Thanks
Re: rhino lining
I have had 2 vehicles lined. Here's my 2 cents:
1) You have to do the careful prep. Remove everything, clean very carefully, scuff it up. It takes a lot of time/work to do it right. There are many outfits that will gladly spray over everything, including metal-metal contact. If rust develops, which it prob will, the liner will eventually bubble and peel off. Remove, clean, remove every speck of rust, then spray primer. 2) The liner: you can do it yourself with room-temp, sprayed or rolled-on material for a decent result, depending on the material you choose and how careful/skilled you are. Some of the crappier materials are little more than rubberized undercoating that will eventually peel/flake off, become discolored, etc. I chose to have a high-temp, hi-pressure poly material (Line-X or equivalent) sprayed on. Expensive, but worth it. Perfect finish, nearly indestructible. It is like sandpaper, tho, so is rough on bare skin. They can also spray roccker panels or the entire exterior, if you want. Again, it comes down to the quality of the material and the skill/detail of your sprayer. CHoose carefully. My guy was like an artist, did a beautiful job (after I spend hours and hours prepping it). Take a sharpie, mark screw holes you want to keep and ones you want to bury. I run my K5 with no carpet, can hose it out. Rear tub area (in front of rear seat) has plastic plugs to remove, hose out, replace. It is an excellent upgrade. |
I know the pieces fit
Re: rhino lining
If you are going to install carpet over the coating, might was to consider Lizardskin as well. I'm going to try it in my 85.
Re: rhino lining
That sounds awesome. Any pics?
Re: rhino lining
I haven't sprayed it yet, I've got a few rust spots to repair first. They've used it on a few Trucks! tv show projects and it appeared easy to apply and came out looking nice. They have two different products, one for heat and one for sound, you can use them together but if you do they say you have to put the sound control down first. I wouldn't expect it to be as tough as a coat of bedliner, it's not what it's designed for. But if you're putting down carpet it doesn't matter anyway.
Windy Corner of a Dirty Street
Re: rhino lining
The interior of my K10 is Rhino lined, Dynomatted with jute in certain spots along with a heavy duty floor mat over all of that. Pretty dang quiet for a big truck. Many people think they can just bed line the floor and call it good. Hmmm, not so much. The bed liner still needs to be covered as it is hot, cold, & loud without anything over it. A buddy and I also did a roll on bed liner in a Ram Charger. That was a total waste of time as it was too thin and peeled right off within a few months even after 2 days of prep work before installing it. Definitely recommend a high quality bed liner such as Rhino, Line-X or even one of the high quality DYI liners like Raptor. Don’t even bother with Herculiner!
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Re: rhino lining
Don't have any of the interior handy, but here's what I got:
Re: rhino lining
That looks awesome. Love the kids car seats in the back. I'm getting my seats redone now. I'll update with pics in the coming days
Re: rhino lining
i want to do something with my suburban but not sure yet i know i want to get rid of the carpet but i know that if i run only bed liner in there it will be noisy i wonder if someone makes rubber floors for the entire truck that i could put over top of sound deadner
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
#10 | |
Re: rhino lining
Re: rhino lining
i was looking and lmc has the molded floormat for the entire suburban
#13 |
Re: rhino lining
#14 | |
Collector of Projects
Re: rhino lining
As far as prep, it ended up being a frame off so the body was blasted when given to the shop. Prior to making my decision I talked to the regional Line-X representative and they wanted to use their primer on bare metal. Without it they wouldn't warranty the job. I also talked to them about colors. I ended up with white on the outside and black on the inside. They have a top coat that is UV blocking and guaranteed the white not to turn yellow. I have also seen them color match an electric blue Ford Raptor bed. Colors cost more so figure that into cost. Also remember that the exterior requires less block sanding so labor is less than a paint job... It ran me $4500 for interior and exterior (including underneath) along with some additional parts. Door panels, inner fenders, grille shell and inner... |
