Old 01-22-2016, 01:28 PM   #1
Bart Savage
Bart Savage's Avatar
LS/Vortec Swap ??
I've read a bunch of threads on this swap but don't have a definitive answer to the exhaust manifold question of do I need to replace the stock ones or not? 63 Suburban getting a 2004 Suburban 5.3 package. Is there a variable there depending on what mounting kit I use or.......? Some kits have headers included. Just trying to keep costs down.....thanks!
Bart Savage is offline   Reply With Quote
Old 01-22-2016, 04:35 PM   #2
suburban99
suburban99's Avatar
Re: LS/Vortec Swap ??
From my recent LS swap experience the stock truck manifolds will not fit inside the frame rails of a '62 C10, that being said the '63 frame may be wider at that point. I ended up using 2010 Camaro manifolds and I have very little room between the flanges and the frame rails. I did not modify the '62 frame but do have a crossmember swap from a '78 in mine...get the whole donor if you can you can also sell it for parts later.
suburban99 is offline   Reply With Quote
Old 01-22-2016, 04:50 PM   #3
Mathew21
Mathew21's Avatar
The truck manifolds would not clear the frame on my 66'. I used Trailblazer SS manifolds. I have read some people notching the frame in order to run the truck manifolds. I'm not sure on the kits I used dirty dingo sliders with my stock 66 motor mounts. I did have to use a Camaro oil pan to clear the crossmember.
There is a lot of great information in the LS swap sub forum http://67-72chevytrucks.com/vboard/f...play.php?f=206
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 01-22-2016, 04:52 PM   #4
suburban99
suburban99's Avatar
X-2 on the Dirty Dingo mounts...stock pan cleared my crossmember as well.
Old 01-22-2016, 10:00 PM   #5
Pro Performance
Pro Performance's Avatar
We just did a LS in a 68. The stock pan will work but hing down a little low for our liking. We went with the GM muscle car pan that you can get for $150.
Dirty Dingo mounts work well.
http://www.azproperformance.com/Dirty-Dingo-67-72-C10/
Pro Performance is offline   Reply With Quote
Old 01-27-2016, 05:37 PM   #6
fast70swb
Where did you get the pan for 150 dollars?
fast70swb is offline   Reply With Quote
Old 01-27-2016, 05:38 PM   #7
Pro Performance
http://www.summitracing.com/parts/nal-19212593
Old 01-27-2016, 05:38 PM   #8
fast70swb
Thank you
Old 01-27-2016, 10:00 PM   #9
72MARIO
72MARIO's Avatar
Could you post a pitcure of how the muscle car pan fits ? I am curious if it hangs below the crossmember at all with the dirty dingo mounts.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-29-2016, 08:50 AM   #10
Pro Performance
I will try and get a picture. We are building it at my parents house, so when I am up there next, I will grab one. It just about even with the crossmember. If it does hang down, it is only about 0.5" or so.... if that at all.
- Travis
