01-24-2016, 06:01 PM | #1 |
Drive shaft questions any input.
I have a long bed I am getting ready to do a swap on. I am running a 4l60e will the original drive shaft work without changing the input shaft. Would rather run a one piece but sounds as if that could be a problem. Take suggestions
01-25-2016, 12:34 AM | #2 |
Re: Drive shaft questions any input.
My truck is older but the driveline from my th350 had to be shortened since the 4l60 is longer. The input shaft was the same though.
01-25-2016, 01:50 AM | #3 |
meowMEOWmeowMEOW
If your running a th350 now, the 4l60e output will match up, but I warn people against making the driveshaft a high priority. Your better off doing the swap the way you want it and having a shaft built to match....instead of setting the build around reusing an older part.
Is your original shaft a 2piece, or was there another reason you wanted to re-use the old shaft?
01-25-2016, 07:44 AM | #4 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-25-2016 at 11:37 AM. |
01-26-2016, 01:20 PM | #5 |
It is a two piece. I.would.rather.have a one piece but some.have said that is to long for a one piece and it may.hit the.crossmember
01-26-2016, 01:58 PM | #6 |
Not necessarily. Make the driveshaft a larger diameter if it is longer
01-26-2016, 02:04 PM | #7 |
the boat guy
I've built a dozen or so one piece shafts for lwb 67-72s
Not a good idea at stock height w trailing arms. Or if you are laying frame on 24"s. Put the engine and trans as far back as you can if you're worried about length.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-26-2016, 02:15 PM | #8 |
It is dropped 4" in the rear.
01-26-2016, 02:58 PM | #9 |
Old member
My 71 LWB has the 4l80e in it with a 1 piece drive shaft and it has a 3" up front drop and 4" out back. No problems so far in 2 years of driving it.
