01-25-2016, 11:08 AM | #1 |
oil pan bolt alignment
I installed the "muscle car" oil pan last night and 2 bolts do not line up. In the picture you can see the hole without a bolt.
The oil pan is this one.http://m.summitracing.com/parts/nal-...FYVAaQodi_YDVA |
01-25-2016, 11:16 AM | #2 | |
The Older Generation
Re: oil pan bolt alignment
How far off is it? Did you try loosening all of the other bolts and put a punch or drift in the hole and gently prying it over? LockDoc
01-25-2016, 11:54 AM | #3 |
I put the same pan on my LS1.......Not sure why that hole is in the pan, but there is no matching tapped hole in the block at that location....
01-25-2016, 12:17 PM | #4 |
Yeah, no hole even close.
So, A1971blazer, you had the same thing but no problems with leaks? |
01-25-2016, 12:39 PM | #5 |
It's the same when installing an LS1 pan on a truck block. I had no leak issues.
01-25-2016, 01:37 PM | #6 |
