Old 01-26-2016, 03:20 PM   #1
Bulldog88
fuel pump question for 88 model 5.3 ls swap
I'm about to do a 5.3 swap on a 88 Chevy Truck but I would like to keep the fuel pump in the tank if possible, has anyone ever done this if so what fuel pump is it that you used, part # or any suggestions would help, I don't think the tbi fuel pump will put out the pressure required for ls
Bulldog88 is offline   Reply With Quote
Old 01-26-2016, 03:24 PM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: fuel pump question for 88 model 5.3 ls swap
I've done it. You just need to swap the in-tank TBI pump with a pump from an LS truck. It should drop right into the old hanger assembly.
A stock TBI pump won't work. They only run about 12 psi, and you need 58 with an LS
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-26-2016, 07:19 PM   #3
68c10airstream
68c10airstream's Avatar
Wasted income is spot on. Your 88 is a return system that can be utilized again if needed.
68c10airstream is offline   Reply With Quote
Old 01-26-2016, 09:10 PM   #4
dec010974
dec010974's Avatar
AC Delco ep381 should be a direct swap. I used the same fuel pump for my 5.3/4l60e swap completed on my 1987 c10. It was a tbi driver also.
dec010974 is offline   Reply With Quote
Old 01-31-2016, 01:24 PM   #5
Bulldog88
Ok guys the swap is going very smooth got the fuel pump in and ready to install it, cheap to not a bad price, what are you guys doing about fuel fittings I would like to keep the existing steel braided lines that are the but they both have male ends, what fittings work?
Old 01-31-2016, 09:57 PM   #6
Cobalt964ruf
Cobalt964ruf's Avatar
here is what i did on the fuel lines at the motor... kept the stock tbi braided lines under the truck... and used the ls fuel lines at the engine. yes its compression fittings, and no i have never had a failure with them. i use them on alot of pressure lines with no problem.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 02-01-2016, 01:13 AM   #7
Bulldog88
Where did you get that set up from?
Old 02-01-2016, 10:48 AM   #8
Wasted Income
Boosted Member
Compression fittings work great for fuel system stuff. Used them many times, never a problem.
Turbo diesel
Old 06-08-2016, 05:02 PM   #9
solidaxel
solidaxel's Avatar
Is this pump strong enough for a 5.3?
PERFORMANCE ELECTRIC P988K Fuel Pump Module Repair Kit Info
Category: Fuel Pump
$37.79
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-08-2016, 08:31 PM   #10
truckdude239
truckdude239's Avatar
Soild i would jsut get an acdelco ep381 there like 40 buxs on ebay and work great no guessing
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-08-2016, 08:57 PM   #11
72MARIO
72MARIO's Avatar
any link to the $40 pump ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-08-2016, 09:26 PM   #12
solidaxel
solidaxel's Avatar
Thanks Dave
I'm on it !!
LS 3 4L70E
Old 06-09-2016, 01:37 AM   #13
izzy_Britton
izzy_Britton's Avatar
http://www.ebay.com/itm/ws/eBayISAPI...861&rmvSB=true
I bought 2 of these... havent started swap yet but dont see why there would be any problems.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 06-09-2016, 01:45 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The most recent review for that pump says that "they didn't send me a 381, its an inferior Chinese generic replacement pump" ....so might be worth being a little careful.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-09-2016, 04:35 PM   #15
Willie Makeit
Willie Makeit's Avatar
Brew makes a good point ... doing a search on Amazon for the AC Delco part number brought up a fuel pump that looks nothing like the on in the ebay ad.
https://www.amazon.com/ACDelco-EP381...=1&*entries*=0
Willie Makeit is offline   Reply With Quote
Old 06-09-2016, 11:13 PM   #16
izzy_Britton
can you please share a link to a proper GM/delco picture of the fuel pump? I have not been able to find a gm/delco supplied photo to use for comparison against my actual ebay purchase mentioned above.
thanks
Old 06-10-2016, 02:37 PM   #17
dayj1
thanks
http://www.rockauto.com/en/moreinfo....031500&jsn=458
dayj1 is offline   Reply With Quote
Old 06-11-2016, 02:02 PM   #18
solidaxel
solidaxel's Avatar
Originally Posted by solidaxel View Post
Thanks Dave
I'm on it !!
Well at least the box says ACDelco and it looks the same!!!
Good service from USPS
LS 3 4L70E
