Old 02-01-2016, 10:02 PM   #1
jeff67cam
Lowering body mounts?
Has anyone lowered the body mounts 73-87 c10? What kind of issues did you run into with steering geometry/ lengths? Was it worth the time, obviously small gains will be made?
jeff67cam is offline   Reply With Quote
Old 02-01-2016, 10:08 PM   #2
tinydb84
tinydb84's Avatar
Re: Lowering body mounts?
Here is a thread where they did it: http://67-72chevytrucks.com/vboard/s...d.php?t=526497
David
Instagram: myfabguy
Old 02-02-2016, 06:48 PM   #3
jeff67cam
I was talking about the steel mounts for the cab and core support not motor mounts, but thanks for the try
Old 02-02-2016, 06:59 PM   #4
tinydb84
tinydb84's Avatar
I know. It starts on post 52: http://67-72chevytrucks.com/vboard/s...4&postcount=52
David
Instagram: myfabguy
Old 02-02-2016, 09:18 PM   #5
HAULIN' IT
Jeff, I did a 2" angled (front to back) bodydrop on mine. I left the front (rad. support mounts) alone, lowered the bulkhead/bedsides/gate 2" on the floor & then lowered the cab mounts to match.
It was some work, however I feel it was one of the best mods I made to our truck & would do it again in a heartbeat if I started to build another truck.
There were no problems with the steering, shift linkage, seat, ect. at the amount I did. I altered the floor between the heavy supports running front to back & had to notch & box the rear cab crossmember the width of the frame as it now is slightly below the top of the frame. I can go into more detail if it is something you think will help. Lorne
HAULIN' IT is offline   Reply With Quote
Old 02-02-2016, 09:48 PM   #6
jeff67cam
Thanks for the input guys, not sure what route to go haha.
