Old 02-02-2016, 10:28 PM   #1
Longley428
1” or 2” lowering block help
Finished up getting the old rear suspension out today, trying to get some advice on doing a 1 or 2 inch lowering block to help get the truck as level as possible. I am using the Hotchkis 4/6 spring kit and I do not want any rake what so ever. But then again I don’t want the rear lower than the front and with seeing pictures of 4/6 drops it still leaves a rake. Any advice?
Longley428 is offline   Reply With Quote
Old 02-03-2016, 07:46 AM   #2
PGSigns
PGSigns's Avatar
Re: 1” or 2” lowering block help
Get the truck put together with the springs and see how it sits. Drive it some and let the springs take a set. See how it sits and go from there. Get it aligned as soon as you get it done as it will be way out after the drop. With that much drop you will need to cut the bump stops off front and rear to keep them from hitting all the time.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
