Old 02-03-2016, 04:56 AM   #1
kerber63
kerber63's Avatar
Wrecked GMC in junkyard
Came across this sad mess today in a local yard. Hopefully the driver was able to walk away. Other than the front, everything else looks pretty solid. I'll be headed back in the next few days to pull some parts.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 02-03-2016, 07:30 AM   #2
PGSigns
PGSigns's Avatar
Re: Wrecked GMC in junkyard
That was a hard hit. Hope he was wearing a seat belt. I can see the old single pot master cylinder on it. Hope it wasn't a brake issue. I wrecked a 64 when it lost a line at the tee in the back. Sick feeling when the pedal gos to the floor. I always recommend folks do the brake upgrade asap on these trucks. Lots of good stuff on that one to help save another.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-03-2016, 09:41 AM   #3
nsb29
nsb29's Avatar
Jimmy
by the looks of that steering wheel he may not have ben wearing his seatbelt and it obviously didn't have collapsible steering shaft
nsb29 is offline   Reply With Quote
Old 02-03-2016, 10:26 AM   #4
60chevyjim
60chevyjim's Avatar
its allways a good idea to make shore that the E brake is in good working condition
in case your brakes should fail.
60chevyjim is offline   Reply With Quote
Old 02-03-2016, 11:26 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Are you able to check if that truck has a 305 in it? Looks like it from here, but I'm wondering if it could Possibly be a 351. Man, Salem is a few hours north of me. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-03-2016, 11:37 AM   #6
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
What yard in salem?
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-03-2016, 11:42 AM   #7
Brad54
Brad54's Avatar
A few years ago, I lost the left rear wheel cylinder on my '54 Buick while coming to a stop. It covered the inside of the drum with brake fluid, so when I stood on the ebrake, one of the two rear drums was well-lubricated.
A '54 Buick Special will not stop on one rear brake drum.
I imagine our trucks won't either.
The truck in the OP took a hit hard enough to shove the steering box back two inches--that's why steering column is spaced out like that.
A lap belt is shown in the pic, but that doesn't keep your chest out of the steering column. Makes me REALLY want to install a collapsible link in mine.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-03-2016, 11:54 AM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
A few years back a local guy here also lost his brakes. The single pot master cylinder.
Splitting the lines was the first upgrade I did to both my trucks.
66 C20 Service Truck:
Old 02-03-2016, 01:16 PM   #9
vin63
It's Better With Nitro
vin63's Avatar
Excellent reminder thread to change out that suicide cylinder.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-03-2016, 02:07 PM   #10
kerber63
kerber63's Avatar
Originally Posted by CHIZZLER View Post
What yard in salem?
Pick a part in Albany. I can check on parts availability and condition for those of you who are just a bit too far away to make this a routine scouting trip, let me know.
1963 C10 short-wide
1963 C10 suburban
Old 02-03-2016, 05:20 PM   #11
KVB
I would be interested in the Heater controls, if all the buttons are intact. It looks good in the pic.
KVB is offline   Reply With Quote
Old 02-03-2016, 05:55 PM   #12
66 GMC 351E
66 GMC 351E's Avatar
I could use the turn signal switch if it is in good working order.
66 GMC 351E is offline   Reply With Quote
Old 02-03-2016, 06:03 PM   #13
kerber63
kerber63's Avatar
Just to be clear, this isn't a "For Sale" thread, I'm just offering to look at parts to save someone from wasting a trip.
1963 C10 short-wide
1963 C10 suburban
Old 02-03-2016, 06:07 PM   #14
bigrigpardo
does the truck have power steering on that v6?
bigrigpardo is offline   Reply With Quote
Old 02-03-2016, 06:52 PM   #15
KVB
I understand that, and I appreciate it. I guess after you look at the parts that are being listed, each of us would have to contact the yard directly and make arrangements with them.
Could you give us the name or phone number of the yard.
Thanks in advance.
Ken
Old 02-03-2016, 08:53 PM   #16
kerber63
kerber63's Avatar
Hey TJ, it's a 305e.
1963 C10 short-wide
1963 C10 suburban
Old 02-03-2016, 08:59 PM   #17
kerber63
kerber63's Avatar
It looks like the return cam got messed up in the wreck.
1963 C10 short-wide
1963 C10 suburban
Old 02-03-2016, 09:00 PM   #18
kerber63
kerber63's Avatar
No power steering.
1963 C10 short-wide
1963 C10 suburban
Old 02-04-2016, 07:11 AM   #19
kerber63
kerber63's Avatar
While climbing around this thing today I found the build sheet behind the seat. Dana 44 3.54 Power Lok (posi), SM420 trans, spare tire mount, wrap-around bumper all intact on the truck. The bumper looks especially straight and clean.
1963 C10 short-wide
1963 C10 suburban
Old 02-04-2016, 07:15 AM   #20
kerber63
kerber63's Avatar
Thanks in advance.
Ken
I'm not affiliated with this yard, but I get a fair amount from them. They seem to get one of our trucks in every 3 or 4 months. They're easy to deal with, I've never ended up on the losing side after haggling.
Pick-A-Part - Albany, OR
541-926-5855
1963 C10 short-wide
1963 C10 suburban
Old 02-04-2016, 09:19 AM   #21
veltex
veltex's Avatar
I could use the bumper, anyone ever try to ship one of these bumpers?
beater 65 gmc at the moment
veltex is offline   Reply With Quote
Old 02-04-2016, 09:26 AM   #22
veltex
veltex's Avatar
did the gauge cluster look decent?
Old 02-04-2016, 11:30 AM   #23
TJ's Chevy
TJ's Chevy's Avatar
Dang! A factory 3.54 posi is fairly rare. Wish I was closer darn it. Might have to call a buddy of mine and let him know about that.
Old 02-04-2016, 11:44 AM   #24
66 GMC 351E
Thanks for checking.
Old 02-04-2016, 01:02 PM   #25
65TRUK
Do you happen to know what year the truck is? Thanks
65TRUK is offline   Reply With Quote
