Old 02-03-2016, 08:58 PM   #1
52MNResto
52MNResto's Avatar
LS Engine install How To/Procedure?
Newbie to the restoration/engine swap, I have a lS1 5.7L. from a 2001 Trans AM with its matching 4L60E transmission. Its going into a 52 Chevy with original frame. I do not have the wheels, tires or bags yet. front suspension is in (Mustang II)
Now I have the ride height measured from a different truck (ground to bottom of frame front and rear). I am wondering if I need to get the wheels, tires and airbags installed before I put the motor and trans. in.
OR
Can I put the truck at my measured ride height mount the engine and transmission than get the bags, wheels, rims.
I have done research but have not really found a definite answer. So what have you guys all done?
52MNResto is offline   Reply With Quote
Old 02-03-2016, 09:55 PM   #2
FarmerSid
FarmerSid's Avatar
Re: LS Engine install How To/Procedure?
I don't have my wheels or tires yet and am using wooden plywood wheels to simulate the size of tires I want to run. I also have solid shock simulators that are adjustable to set ride height. I can move on with the build and save for those $$$ parts layer on.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-03-2016, 10:22 PM   #3
Advanced Design
Advanced Design's Avatar
Welcome MN52resto. I agree with Sid. Go ahead with installing the engine and transmission.
Advanced Design is offline   Reply With Quote
