Old 02-06-2016, 01:54 PM   #1
1972K20
1972K20's Avatar
2 or 3 Leaf Front Springs?
I've been looking at ordering factory replacement front leaf springs for my 72 k5 and I've seen springs with 2 and 3 leaf offered. Which is correct, and is there a need for the 3 leaf pack? Thanks
1972K20 is offline   Reply With Quote
Old 02-06-2016, 05:17 PM   #2
RedRoad
RedRoad's Avatar
Re: 2 or 3 Leaf Front Springs?
3 leaf packs are HD from the factory and give a slight lift
RedRoad is offline   Reply With Quote
Old 02-14-2016, 02:44 AM   #3
BigRed76
BigRed76's Avatar
Not sure which is correct for a K5, I'm sure they could've come with either from factory. If you have a big block or a heavy front bumper with a winch then the 3 leaf might be better. If not I'd recommend sticking with the 2 leaf since they will ride slightly better.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-14-2016, 02:46 AM   #4
picklito
Different animal, but relevant: My stock 77 K10 had 2-leaf. Local spring builder made a very nice tapered 3-leaf that leveled the truck and rode way better.
picklito is offline   Reply With Quote
Old 02-14-2016, 12:40 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My K5 and K25 both had 2 leaf, the CUCV axles I have gotten and my son's 86 CUCV all have 3 leaf fronts.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-14-2016, 03:58 PM   #6
picklito
Also, I always thought the stock negative arch that many of the GM 2-leaves came with... rode horribly. If you can get a little positive arch I feel they ride much better, even if your final spring pack has a little higher spring rate.
