Old 02-17-2016, 10:36 AM   #1
bumwine
bumwine's Avatar
Clyde's '65 BBW "Bonnie"
Ok so I had started a build thread for this truck but some things have changed and wanted to start over on my personal account. So here we go again
I picked up this '65 a little over a month ago. She started out her life as a Doran Chevrolet service truck. She's got a 283 that's seems fairly strong. I will run it for now until I get to that stage. Eventually she will be bagged with the works but for now. Its going to be static drop with big brakes, rims, new wiring, etc
bumwine is offline   Reply With Quote
Old 02-17-2016, 10:38 AM   #2
bumwine
bumwine's Avatar
Re: Clyde's '65 BBW "Bonnie"
I have already done some spray paint removal
Old 02-17-2016, 10:41 AM   #3
bumwine
bumwine's Avatar
Also knocked down some surface rust and got a nice patina look. I plan on painting her down the road but for now this will have to do
I also have a full time "helper" it will be his truck one day
Old 02-17-2016, 10:56 AM   #4
bumwine
bumwine's Avatar
replaced the ball joints and got the hotchkis springs installed it's a 4/6 drop with 2" cpp drop spindles. Also rebuilt the rearend a bit and installed the new axles. Started on the brakes too
Old 02-17-2016, 10:59 AM   #5
bumwine
bumwine's Avatar
I have the rims but I'm still have to get tires but not sure what route I want to go yet. Went with 17x8 in the front and 17x9 in the rear
Old 02-17-2016, 12:17 PM   #6
62stepside longbox
62stepside longbox's Avatar
Nice truck! Digging the patina
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-17-2016, 01:07 PM   #7
scoot_mcgrute
What did you use to get rid of the spray paint?
I've got a patch of black spray paint on my rear fender that I would like to see gone.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 02-17-2016, 01:13 PM   #8
bumwine
bumwine's Avatar
Thanks!
Old 02-17-2016, 01:14 PM   #9
bumwine
bumwine's Avatar
Green scotch brite and CLR. Took a decent amount of scrubbing but came off
Old 02-17-2016, 01:28 PM   #10
scoot_mcgrute
Awesome, I was already planning on doing that to the truck. Thanks!
1966 Army Truck
Old 02-17-2016, 01:44 PM   #11
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looks good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-17-2016, 10:38 PM   #12
bumwine
bumwine's Avatar
Started on running the new ebrake lines but needed to do some research on the final steps so I moved on to replacing my harness. Now I'm debating on restoring my cluster
Old 02-28-2016, 02:09 PM   #13
bumwine
bumwine's Avatar
Haven't had too much time to work on the truck but with a hour here and there I've managed to get some more electrical done. Removed the power booster someone converted the truck to. they kinda hacked up the firewall a bit. I'll have to fix that down the road when it gets body worked and painted.
Old 03-11-2016, 01:09 AM   #14
bumwine
bumwine's Avatar
Not much to update with lately. Been too busy to work on the truck. Managed to start playing with the new master though
Old 03-11-2016, 05:34 PM   #15
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Old 03-13-2016, 11:40 AM   #16
Bomp
Bomp's Avatar
Do you have the part number for that new master?
Like what I'm seeing.
Both feet on board, Sub'd
Bomp is offline   Reply With Quote
Old 03-13-2016, 11:44 AM   #17
bumwine
bumwine's Avatar
I got it from the guys at az pro performance. Great guys and excellent customer service
http://www.azproperformance.com/Wilw...261-13269.html
Old 03-15-2016, 11:34 PM   #18
ChrisDollins
ChrisDollins's Avatar
Love the truck man. The chrome cragars look right at home.
Chris
ChrisDollins is offline   Reply With Quote
Old 03-16-2016, 12:59 AM   #19
bumwine
bumwine's Avatar
Chris
Thanks! Now if I could get some rubber on them and set her back on the ground
Old 03-18-2016, 12:00 AM   #20
bumwine
bumwine's Avatar
I came across a intake and carb for cheap so I decided the engine could use a make over
Old 03-18-2016, 03:25 AM   #21
Paul Y
Very nice Sir.
P.
Paul Y is offline   Reply With Quote
Old 03-19-2016, 01:09 AM   #22
MisterC
MisterC's Avatar
I'm loving the direction that you're heading on this. Well played!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 03-19-2016, 09:35 AM   #23
Bomp
Bomp's Avatar
Level Up
Steps in the right direction. Diggin' it
Old 03-19-2016, 09:46 AM   #24
bumwine
bumwine's Avatar
Thanks everyone! The shock relocation brackets showed up yesterday.
Old 03-20-2016, 06:37 PM   #25
bumwine
bumwine's Avatar
Knocked out the front shock relocation today. Man these Cpp brackets are a pain with the cab on
