Old 02-17-2016, 10:46 AM   #1
earl84
Wiper arm and blades P/N's that work, FYI
My truck had no wiper arms when I bought it, so I purchased some stainless steel arms from LMC. Not great, to say the least. The quality was so-so, but more important, the top 2 inches or so of the blade was never in contact with the windshield, and the center of the blade contact was not very good, either, making them almost worthless.
Somewhere I ran across a part number for wiper arms that are adjustable in length and wiper blade angle, and they work great, the full blade is clearing the window, they park perfectly, the length is perfect. Just thought I'd pass this along, I've been looking for a good solution off and on for over a year.
Trico part number 51-151 for the wiper arm. They are a dull silver finish. About $12 apiece at O'Reilly Auto Parts.
Anco part number 31-13 for the wiper blades. These are the winter blades, not sure on a part number for summer blades.
earl84 is offline   Reply With Quote
Old 02-17-2016, 11:38 AM   #2
MikeN
MikeN's Avatar
Re: Wiper arm and blades P/N's that work, FYI
Thank you!
MikeN is offline   Reply With Quote
Old 02-17-2016, 12:34 PM   #3
sanford66
sanford66's Avatar
Thanks for the tip, I've been fighting this for the last month or so, can't find anything that works. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 02-17-2016, 12:35 PM   #4
undertaker72
undertaker72's Avatar
Thanks for the help
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 02-17-2016, 03:45 PM   #5
oakstcustomz
oakstcustomz's Avatar
Yes thanks!! I bought the same but my wipers are the same color as the arms... I got taken for over $100 for the set by my friendly local napa auto parts
1965 Chevy C-20 slammed 292 L6 TH400
1967 Chevy C-20 on 91 suburban frame project(wife's)
1972 Chevy K-20 Mild 350/th350/np2o5 dd
1952 Ford Customline 2door kustom project
1967 Cadillac Superior Hearse (wife's)
1998 GMC Saffari (wife's dd)
oakstcustomz is offline   Reply With Quote
Old 02-17-2016, 04:18 PM   #6
motaboata
Thanks!! Same issue truck has no arms... lots of rain-x was used! this will help
motaboata is offline   Reply With Quote
Old 02-17-2016, 08:51 PM   #7
Thank you for the info, VERY useful.
Old 02-17-2016, 10:54 PM   #8
60chevyjim
60chevyjim's Avatar
I found these on ebay today ,
after the ones from lmc for my friend's truck got here today.
these look way better than the ones he got today
http://www.ebay.com/itm/1960-1966-Ch...B_iR-WwEdpWc1g
60chevyjim is offline   Reply With Quote
Old 03-06-2016, 12:24 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
How are they working out for you?
66 C20 Service Truck:
Old 03-06-2016, 01:01 PM   #10
frankslagoon
Earl. what year is your truck?
frankslagoon is offline   Reply With Quote
Old 03-06-2016, 01:38 PM   #11
60chevyjim
60chevyjim's Avatar
I didn't buy them yet but I use similar ones on my
59 and 60 chevy cars and they work pretty good .
Old 03-06-2016, 10:30 PM   #12
WOLFMANmike
WOLFMANmike's Avatar
im not sure if they are the same as the LMC ones or not but i ordered the ones from Orange truckshop.com for our trucks and have no problems at all with them and they are Stainless Steel
WOLFMANmike is offline   Reply With Quote
Old 09-20-2019, 06:26 PM   #13
C40
The truck I bought has no wiper blades. Will someone please let me know what is the correct size blades for the 60-63? Thanks
C40 is offline   Reply With Quote
Old 09-21-2019, 07:48 AM   #14
13" is the standard size
Old 09-21-2019, 12:38 PM   #15
C40
Will 15” fit ?
Old 09-21-2019, 02:29 PM   #16
I think they will hit in the middle, but I have never tried them.
Old 09-21-2019, 04:35 PM   #17
vince1
For the RH side I have the one from the back of a Jeep Cherokee. I haven't found one yet to modify for the LH side.
vince1 is offline   Reply With Quote
Old 09-22-2019, 10:01 AM   #18
scottofksu
scottofksu's Avatar
Are these the blades you tried? If not, has anyone tried these?
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 09-22-2019, 04:43 PM   #19
If you can find them, yes those are the good ones. Normally, NAPA or other parts places do not keep them in stock, least that is the way it is around here.
Old 09-29-2019, 04:48 PM   #20
rideblue00
rideblue00's Avatar
Subscribed
rideblue00 is offline   Reply With Quote
Old 09-29-2019, 06:24 PM   #21
norcalcap
I used the same one, just drilled out the rivet, flipped the arm and new rivet. Works great. Just a little tough removing and replacing the tension spring.
norcalcap is offline   Reply With Quote
