Old 02-20-2016, 05:04 PM   #1
kingsolver72
10/30/19
kingsolver72's Avatar
Lowering gurus
I need help identifying the passenger side lower control arm on my 1999 GMC Sierra,2 wheel drive. None of the parts store near me have any clue. I'm guessing the arm is a drop.
kingsolver72 is offline   Reply With Quote
Old 02-20-2016, 05:05 PM   #2
kingsolver72
10/30/19
Re: Lowering gurus
Other side.
Old 02-20-2016, 05:07 PM   #3
kingsolver72
10/30/19
Re: Lowering gurus
Hers a pic of the truck with the lowered stance.
Old 02-20-2016, 05:10 PM   #4
kingsolver72
10/30/19
Re: Lowering gurus
Side view.
Old 02-20-2016, 05:57 PM   #5
kingsolver72
10/30/19
Re: Lowering gurus
Ok I think it may be a DJM lca. Can anyone verify?
Old 02-20-2016, 07:48 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lowering gurus
sure looks like DJM.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 02-20-2016, 08:33 PM   #7
kingsolver72
10/30/19
Re: Lowering gurus
Thanks. Can you tell if it's a drop or oem height?
I've read good and bad things about DJM products.
This lca broke loose from the front bushing.=(DisJointedMember)
Old 02-20-2016, 08:53 PM   #8
lolife99
lolife99's Avatar
Re: Lowering gurus
Those are drop a-arms.
I had the uppers and lowers on my '99 silverado.
I don't think DJM makes a standard height a-arm.
I would put some stock a-arms on with drop spindles.
Keith
Old 02-20-2016, 09:14 PM   #9
kingsolver72
10/30/19
Re: Lowering gurus
I kind of want to go back to factory height but I don't/can't spend that much money on it right now. I can purchase a pair of DJM lower for the price of one oem lower. I may keep an eye out on Craigslist.
Old 02-20-2016, 09:19 PM   #10
BLUIDVL
BLUIDVL's Avatar
Re: Lowering gurus
I have to agree, they look like DJM.
BLUIDVL is offline   Reply With Quote
Old 02-22-2016, 03:55 AM   #11
kingsolver72
10/30/19
Re: Lowering gurus
Would anyone like to venture a guess of how much drop the lca is? Looks like the spring has one coil cut off. 20" wheels. Does the truck look like it has a 3/5 drop? How do you go about determining how much drop is in the arm?
I forgot to mention that the rear has shackles, not a flip kit and no c notch.
Old 02-23-2016, 01:14 AM   #12
crazy longhorn
Fabricate till you "puke"
Re: Lowering gurus
This may be a bit trial/error, but from what I see on the arms....I would not purchase another set of them! If you want to keep the height, run a stock a arm/2"drop spindle. After that, you can trim the spring to fit the height that you need. Figure that 1 full coil , will be around 2 " of drop....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-23-2016, 05:41 PM   #13
kingsolver72
10/30/19
Re: Lowering gurus
I have been wondering how many leaf springs the factory installed on these trucks. If the previous owner pulled a leaf then that changes things. Anyone know how many leaves/leafs there is supposed to be?
Old 02-23-2016, 08:23 PM   #14
kingsolver72
10/30/19
Re: Lowering gurus
Looks like 5 leaves per spring is factory. The truck has 3 leaves. The p.o. removed 2 leaves. Not sure how much that drops the rear end.
Old 02-24-2016, 05:10 PM   #15
thomas_a_reed
thomas_a_reed's Avatar
Re: Lowering gurus
Check rockauto.com they look to be about $85 and up plus shipping for new stock ones and I'm sure you could pick one up at a local junkyard for $40 to $50..
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 02-25-2016, 10:20 PM   #16
Flying Hamster
Flying Hamster's Avatar
Re: Lowering gurus
NO F---ING WAY would I get another A-arm like those!!!
That is serious JUNK and will kill you.
Real poor quality welds and questionable design.
Flying Hamster is offline   Reply With Quote
