02-25-2016, 10:57 PM | #1 |
Driveshaft
Putting a 5.3 with the 4l60e in a 66 suburban same wheel base as a short bed pickup. What are you guys using for a driveshaft the orginal or one from the donor I have both thanks
02-25-2016, 11:12 PM | #2 |
Re: Driveshaft
I had my original drive shaft shorten and balanced
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-01-2016, 11:19 PM | #3 |
Re: Driveshaft
Anyone using the donor vehicle one piece driveshaft. Any clearance problems through the frame, I have the driveshaft out of a 04 chevy truck and as I mentioned before the orginal 66
03-02-2016, 08:43 AM | #4 |
Re: Driveshaft
Does your "new" driveshaft have a balancer on the front yoke.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
03-02-2016, 10:26 AM | #5 |
the boat guy
Re: Driveshaft
I built the driveshafts for my truck. To fit MY truck. Go to your local driveshaft builder with your new and old shaft, measurements and money. Done
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
03-02-2016, 01:58 PM | #6 |
Re: Driveshaft
Will the new one piece driveshaft fit through the frame without interference, as in movement up and down?
03-07-2016, 09:30 PM | #7 |
Re: Driveshaft
mine has the balancing weight on the front of the drive shaft
