Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 02-29-2016, 05:20 PM   #1
Double Stack
Double Stack's Avatar
Rear Bench Seat Belt Replacement
Hey guys, anybody ever replace the center seat belt for the rear extra cab bench? My problem area is the metal guide bracket that's near the top of the back rest and in front of the window. How did you rout the new belt through this piece? 2007.5 1500 extra cab.
Double Stack is offline   Reply With Quote
Old 03-02-2016, 07:14 PM   #2
Double Stack
Re: Rear Bench Seat Belt Replacement
Does anybody have access to Alldata.com? I don't seeing as I'm not working for a dealer right now. That's about the best I can think of for this seat belt deal.
Old 03-02-2016, 07:47 PM   #3
Double Stack
Picture so we're on the same page.
Old 03-03-2016, 12:18 AM   #4
Double Stack
For anybody in the future, you cut the plastic molding/trim that fits over the top of the metal bracket. That's straight from GM. Great engineering.
Old 03-03-2016, 08:37 AM   #5
95 S_Trucker
95 S_Trucker's Avatar
It's a little late.
If you loosely remove the trim panel, then unbolt the bottom of the seat belt(not the retracting end) and then fish it out if the trim panel.
Edit: this only shows the outer belts. Not the center one. But that belt made it through the hole, so it should come out.
95 S_Trucker is offline   Reply With Quote
Old 03-03-2016, 11:32 AM   #6
Double Stack
Right on, thanks for the reply.
My brain was focusing on the metal bracket when I only really needed to worry about the plastic trim. I ended up going over to a dealer and they were cool enough to pull up the gm version of alldata.com. It says "cut trim" even those guys were baffled at he the crappie design. Today I'm making a thin cut to slide the belt through.
