Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-01-2016, 08:22 PM   #1
kdh454
Made Some Custom Kickpanels This Weekend
My '75 crew cab was in serious need of an audio system and a single center speaker was just not going to cut it so I installed a new head unit from Retro Sound and made myself a set of kick panels to house some Image Dynamics 6.5" components.
Kick panels were made with with MDF and fiberglass. I have yet to find a paint that matches the interior but I think they came out OK. As soon as I find a color to match, I'll repaint them along with the grills. The 6.5" grill is currently off because I did not have long enough screws.
Next step is a sub, rear speakers and an amplifier or two.
kdh454 is offline   Reply With Quote
Old 03-01-2016, 11:55 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Made Some Custom Kickpanels This Weekend
Looks good to me! Nice job. Go to local auto paint store and have them match it up with a color gun. They will walk out to the truck and zap it and it spits out the color number.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-04-2016, 01:29 PM   #3
_Ogre
_Ogre's Avatar
they look good, awesome work
shop air compressor timer
Old 03-10-2016, 12:28 PM   #4
NJ C10 Guy
I will be doing the same. I have the rings cut out for mine and I am trying to dry fit but I am running into an issue with the e-brake. I can't find the right angle to use where the e-brake pedal clears the kick panel. Although I have an automatic and doubt I will ever need to use it, I want to know it's there if I need it. What did you do to solve this?
NJ C10 Guy is offline   Reply With Quote
Old 03-10-2016, 02:55 PM   #5
kdh454
If the ebrake is not adjusted tight enough it will hit the kick panel, you just have to be conscious of it. Not a perfect solution but modifying the pedal did not look fun.
