Old 03-03-2016, 10:40 AM   #1
Vandals909
Poly mount?
Should I run poly inserts on my clam shell mounts? I searched and some guys don't like them. Some guys say the other rubber replacement fall apart so poly is the only ones that hold up
Vandals909 is offline   Reply With Quote
Old 03-06-2016, 07:46 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Poly mount?
Yes, I would go poly...(Did that)/ they will have a little more vibe @ idle speed, vs the rubber parts, but they do hold up Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-07-2016, 02:19 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Poly mount?
My rubber sbc mounts didn't like 400+hp and any age at all. I ran them for a couple years but the engine had far more movement than I would have been comfortable out on the track. I swapped out for poly mounts and like the change.
The poly mounts don't vibrate all that much more than the rubbers. If your making good power, then rubber mounts will wear and vibrate a good amount, so the poly change might not be that noticeable at all.
My 4l80e stock mount has held well tho, at least so far, ~5 years.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
