![]() Join Date: Apr 2000
good deal?
An 01 5.3 pullout with everything, wiring, manifolds, fuse box, cruise control box and cable, flexplate, accessories, computer with 168k for $750.
too many miles?? guy suppose to have vid of it running...
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
meowMEOWmeowMEOW
Re: good deal?
Drive by cable I assume? Thats not really a bad price if its uber complete. Yes its high mileage, but if your thorough, that might be ok.
A running vid is good of course (but it doesn't 100% mean it actually runs, sadly). If its in good physical shape and has no obvious defects, your odds go up to 50-50. If you can use a scope to look in the cylinders, or maybe pull the oil pan, you can get those odds up a bit more. If the cylinders look good, and the bearings all seem to be there (no metal shavings), then your probably alright. Put a timing chain kit, an oil pump kit, possibly the water pump....your in good shape. I would say this applies so long as your looking for a good runner, with a couple performance goodies. If your really looking to turn up the wick, I'd only suggest it if your doing a rebuild...or not afraid to be doing one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: good deal?
I would only buy a used LS motor if 1) I can test drive it and pull compression or 2) if it's mounted on a stand that I can test run it and pull compression (and have coolant running through it).
Re: good deal?
thanks guys,not too many for sale in my area..
Re: good deal?
I just went through a bad experience buying an LS on someone's word so I defiantly would not buy again without hearing it run first!
If you live in Oklahoma click this link |
Boosted Member
Re: good deal?
Yea, it seems hit or miss. I think you guys are on point regarding buying LS stuff from craigslist mouth breathers and the sort. I've never bought one of those, but I've bought a half dozen of them from my local wrecking yard, without hearing them run, and haven't been burned yet.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Re: good deal?
i`m waiting on my local yard to get one in,they get bought up right now around here..
#8 | |
Re: good deal?
