03-12-2016, 10:39 PM | #1 |
72 C30 dualler
Hello, I am new to the forum. I am presently building a 1972 Chevy C30 1Ton dually. I have come across a problem that no one seems to be able to help or know about. This truck has budd wheels on the rear and regular steel wheels one the front. It has disc brakes on the front also. I want to put a budd wheel on the front so that I will only have to carry one spare. How do I accomplish this. Do I have to get new spindles and hubs for the budd offset, or can I use an adapter to off set it?
03-12-2016, 10:53 PM | #2 |
Re: 72 C30 dualler
Welcome ,I dont have an answer but Im curious too.
03-13-2016, 09:00 AM | #3 |
Re: 72 C30 dualler
Post some pics , parts may have been changed.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
03-13-2016, 09:49 AM | #4 |
Re: 72 C30 dualler
Find you a one ton say 73-87 and do a crossmember swap that may be the quickest and painless way to go then you have really good parts to sell someone that needs a disc brake change over for a 67 -70 truck. The General did make C-30's with the single wheel. It sounds to me someone either converted a single wheel one ton or a C20 to a one ton.
If I recall it might be the same parts in the front for the C-20 and C30, but I'm sure someone on here that has been into more of them than I have will speak up. I DO know on the later trucks say the 88-98 body style that the C6P[heavy duty] 3/4 [8 lug]ton truck had the same front end stuff as the single wheel one ton. [just a side note in those years 88-98 there were two different 3/4 tons. A light duty [7200 GVW 6lug] and a [8600 GVW8 lug] heavy duty. I loved building those 3/4 tons back then easy sellers in farm country. Jim |
03-15-2016, 02:37 PM | #5 |
Re: 72 C30 dualler
Jim, This is a true C30 according to the VIN. Dual wheels on the rear. All I want to do is put a budd wheel on the front, it seems awful drastic to have to change the whole front end just to achieve this. Thanks for the input, I will let you know how I solve the problem.
03-15-2016, 02:45 PM | #6 |
Re: 72 C30 dualler
03-15-2016, 04:21 PM | #7 |
Re: 72 C30 dualler
Does it specify R05 Dual Wheel Conversion on the SPID? Was it a pickup originally? All too often a base C30 (SRW) will have a dually axle added out back. Its also possible that someone installed used C20 or C30 SRW rotors up front as easy replacements at some point.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-15-2016, 04:33 PM | #8 |
Re: 72 C30 dualler
This is the part I think that you are looking for:
https://bakersfield.craigslist.org/pts/5479769267.html |
03-15-2016, 04:51 PM | #9 |
C10 Collector
Re: 72 C30 dualler
I'm not sure about the 72 but the later trucks 73-87 the offset hub was part of the front rotor. I think these are interchangeable with the single wheel front rotor but not positive. Or you could maybe get a dually adapter from a 01-07 3500hd. These trucks used bolt on adapters instead of being made into the rotor.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
03-17-2016, 08:56 AM | #10 |
Re: 72 C30 dualler
X2 on the rotor swap I think it's the same on the 72 as well if you need the parts I have a 72 C/30 with budd wheels I am parting out I'll send a pm thanks Jeff
03-17-2016, 09:46 AM | #11 |
Re: 72 C30 dualler
they make an adapter you can buy to do this. to me that would be the easy way to do this.
short bed are just cars without trunk lids trucks have long beds real trucks are longhorn 72 gmc 2500 longhorn 68 chevy c-30 50th anniv. 9ft step side 68 gmc crackerbox 8v71 detroit 72 gmc astro95 8v71 detroit |
03-19-2016, 09:02 AM | #12 |
Re: 72 C30 dualler
If you can find the offset rotor for 71-72 you can just swap it on. I have not been able to find them new. If you find a 73-87 donor vehicle you can just swap everything between the ball joints. no need to swap the cross member. I just did this swap on my 71 c 20. I used the spindle rotor caliper and brake lines from a 78 C 30 with bud wheels and it worked like a dream. I kept my same cross member same a frames, same ball joint same tie rods. Bolt on conversion. The only thing I did was re route the brake line a bit. The same set up also works from G model trucks (boxvans) all the way up to 95 I believe. The rotors , brake lines and calipers are easily available new. All you really need from the donor is the spindles. However, If Jeff's Bowtie's has good rotors from a 72 buy them ,its the easiest way.
03-19-2016, 11:55 AM | #13 |
Re: 72 C30 dualler
I used 1986 C 30 parts. 1968 inner tie rod's, 1986 outer tie rod's onto the parts. Brand-new rotors and calipers. 1986 ball joints and spindles. It worked out very well.
03-20-2016, 11:48 AM | #14 |
Re: 72 C30 dualler
Maybe 71-72 tie rod ends are different than 67-70 but mine from the 71 fit the 78 spindle perfectly as did my ball joints.
03-20-2016, 12:03 PM | #15 |
Re: 72 C30 dualler
Arrowcraft products in royal oak Michigan sells bolt on adapters
03-23-2016, 01:53 AM | #16 |
Re: 72 C30 dualler
Thanks for the info. I will see what happens.
03-23-2016, 02:01 AM | #17 |
Re: 72 C30 dualler
Sweet truck, I compliment the workmanship. Thanks for the info, I will check it out.
