Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-13-2016, 12:38 AM   #1
azdude1964
azdude1964's Avatar
twin turbo 540
Anyone got this setup in their truck ? or I going to be the First.
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 03-13-2016, 04:41 PM   #2
Blue Rat
Re: twin turbo 540
Well I guess we are waiting for fat tires an big horse power pics.
Blue Rat is offline   Reply With Quote
Old 03-14-2016, 08:34 PM   #3
Gary V
Active Member
Gary V's Avatar
Re: twin turbo 540
Like the title... details please
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 03-16-2016, 12:16 AM   #4
azdude1964
azdude1964's Avatar
Re: twin turbo 540
Well, I was inquiring to see if anyone has done it yet or am I the first to do it.
So lets start with the truck . 1964 C10 short bed small window the one in my avatar. dropped 3inches in front 6 inches out back. coilover on rear 250lb spring adjustable shock. 9 inch that measures 52 inches hub to hub 18x29x15 tire street/13inch slick strip. Boxed frame and going to do some more chassis work. Front suspension is cpp tubular arms with sway bar. Custom disc brakes on all four corners . I will take pics as it comes together.
Lets talk about the fun part, the engine. BBC 540 twin turbo.
heads AFR 325 cnc
intake edelbrock efi
block Dart Big M with billet mains
crank eagle 4.25 forge (what I had)
rods eagle 6.385 H beam Arp 2000 bolts
turbos are BW s480 80/93 1.32 ar
cam is going to be custom grind and running crower shaft rockers
Old 03-16-2016, 07:28 AM   #5
djracer
djracer's Avatar
Re: twin turbo 540
Sounds sweet! Is it still trailing arms in the rear?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-16-2016, 02:18 PM   #6
azdude1964
azdude1964's Avatar
Re: twin turbo 540
yes it is will post pics soon
Old 03-16-2016, 02:49 PM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: twin turbo 540
I've got a turbo setup in my truck...but only on 370 cubes.
I am planning to put together a similar TT 540 BBC setup in my Chevy II though.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-16-2016, 10:28 PM   #8
djracer
djracer's Avatar
Re: twin turbo 540
I have a really nice 548 I will sell you but you would just have to swap pistons to be boost friendly! I think I really want a bigger Motor.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-16-2016, 10:41 PM   #9
azdude1964
azdude1964's Avatar
Re: twin turbo 540
I got all the big parts already.
Old 03-17-2016, 04:56 PM   #10
Racer382D
Racer382D's Avatar
Re: twin turbo 540
Talk to me about the 548.
Racer382D is offline   Reply With Quote
Old 03-18-2016, 03:44 AM   #11
scatesracing
Machinist
scatesracing's Avatar
Re: twin turbo 540
This is my twin turbo build..... Im a little shy of the 540ci mark
scatesracing is offline   Reply With Quote
Old 03-19-2016, 05:43 AM   #12
Gary V
Active Member
Gary V's Avatar
Re: twin turbo 540
heads AFR 325 cnc
Good stuff! Looking forward to seeing the progress pics and info.
Best regards,
Gary
DOMERINGER BUILD
Old 03-20-2016, 03:59 PM   #13
azdude1964
azdude1964's Avatar
Re: twin turbo 540
Ok got a little work done today. tore the 514 gear set out and put a 350 in running a Moser bolt through third member. working on a bigger fuel cell next. here are some pics . that's one of the turbos a teaser..lol
Old 03-23-2016, 01:57 AM   #14
azdude1964
azdude1964's Avatar
Re: twin turbo 540
got the tank almost done .got to finish tomorrow.
Old 03-23-2016, 07:45 AM   #15
djracer
djracer's Avatar
Re: twin turbo 540
I would put a back brace on the 9 inch.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-24-2016, 06:04 AM   #16
Gary V
Active Member
Gary V's Avatar
Re: twin turbo 540
Nice! What kind of fuel pump are you going to use? Rear end is 3.25 tube? Looks stout... nice setup!
Best regards,
Gary
DOMERINGER BUILD
Old 03-24-2016, 12:29 PM   #17
azdude1964
azdude1964's Avatar
Re: twin turbo 540
yes 3.25 tubes dom running a external pump that's good for 1000 hp to start(its what I got) then upgrading to something that will handle 1500hp
Old 03-24-2016, 07:29 PM   #18
tinydb84
tinydb84's Avatar
Re: twin turbo 540
At what HP Rating do you starting thinking about a back brace?
David
Instagram: myfabguy
Old 03-24-2016, 08:13 PM   #19
Blue Rat
Re: twin turbo 540
I would think it was more about weight at traction. I'm sure HP an Torque wise you fall right in the middle of when a back brace would be recommended. I'm going to be watching this build.
Old 03-24-2016, 09:43 PM   #20
azdude1964
azdude1964's Avatar
Re: twin turbo 540
don't plan on back brace do to the DOM tubing and the narrow rear . also not using a trans brake .
Old 04-12-2016, 12:40 AM   #21
azdude1964
azdude1964's Avatar
Re: twin turbo 540
started on the hot side of the turbo's t6 flange 4 into 1 2 inch sch 10 stainless
Old 10-20-2018, 07:12 PM   #22
1Bad72C10
Re: twin turbo 540
i'm subscribed doing this exact build right now in my 72 street truck.
Dart big m block 9.8
callies billet crank and billet rods
diamond pistons
dart pro 1 355 cc heads
crane gold roller rockers
custom grind cam
jesle belt drive
daily engineering drive sump set up
twin bullseye 83 mm turbo's
all arp bolts and studs
holley dominator efi
16 moran billet atomizer injectors
plazmaman billet intake
edelbrok victor water pump
coil on plug
im running a fab 9 moser housing with back brace and 3.00 gears
a rossler 4L80E stage 5
trying to figure out how to fit a water to air intercooler system with a killer chiller
20x14 budniks in the back with 29x15x20 mickey thompson tires
sounds like we are both building something very similar
1Bad72C10 is offline   Reply With Quote
Old 10-22-2018, 11:34 PM   #23
azdude1964
azdude1964's Avatar
Re: twin turbo 540
Ok everyone making progress on the 64 I hope to have it running soon . so here are so pic to show what I've got done..
Old 10-22-2018, 11:41 PM   #24
azdude1964
azdude1964's Avatar
Re: twin turbo 540
more pics... sorry I don't know how to rotate the pics. the engine in the truck is a mock up[ATTACH]Name:  IMG_0043.JPG
Size:  47.2 KB[/ATTACH]
Old 10-22-2018, 11:50 PM   #25
azdude1964
azdude1964's Avatar
Re: twin turbo 540
a couple more
